Diff removal
Wafoo
Diff removal
Post by Wafoo » Tue May 15, 2018 7:15 pm
Trying to get the diff off but struggling
What's the best way to lock the propshaft to stop it turning?
I've got the handbrake on as hard as it will go and stuck it in reverse but still the bloody thing is turning
Merlot 2.2i SE, so far new discs and pads, seats replaced, Cam cover replaced, Roof now fixed, new diff x3, new halfshafts, new drop links and other bouncy bits,
GuidoK
Diff removal
Post by GuidoK » Tue May 15, 2018 7:43 pm
To get the inverse torx bolts off the diff drive flange?
I always put a tyre iron between the rear universal joint.
The end of the tire iron wedges against the fuel tank I believe when you turn the propshaft so you can use both hands to fiddle with the bolts etc.
Ducklakeview
Diff removal
Post by Ducklakeview » Tue May 15, 2018 8:53 pm
Impact wrench if you can borrow one. Will remove them without needing to lock it. Failing that, someone in the car on the brake pedal.
Mike
wonkydonkey
Diff removal
Post by wonkydonkey » Tue May 15, 2018 9:59 pm
For reference, first gear is normally a lower ratio than reverse.
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
GuidoK
Diff removal
Post by GuidoK » Tue May 15, 2018 10:17 pm
You'll still need to lock them when putting the new diff in and torquing the bolts to spec.
Wafoo
Diff removal
Post by Wafoo » Thu May 17, 2018 7:43 am
Thanks all, jammed a bit of 4x2 on the brake pedal and they came off lovely
Front mounting bolts on the diff as well were surprisingly easy
Just got to shift the mounting bolt at the rear which has so far refused to shift and bent a spanner!
Doused in penetrating oil and left till the weekend now 😁
