Another issue
- williamdefender
Another issue
I had the same noise and it was the top mount of the shock . I was able to replicate the sound by lifting the car up and down . I put both hands at front wheel arch and lifted the car up and down , sound was very easy to hear . Might be worth a punt as i found all bushes etc to be ok .
Another issue
You'll need a pry bar to move stuff not hands. Put a pry bar in between tie bars/ arm/ etc and get easy movement. If smooth movement it normally means all ok but moving stuff around with the force of a bar you may be able to see splits in bushes etc.
Another issue
Maybe check the brake disc cover plates, they tend to rattle like a bugger once they come loose.
Midnight blue, 3.0si sport coupe, champagne nappa leather, piano black trim, stubby, DLV exhaust and a bunch of other stuff
- MT94
Another issue
I have check the disc brake back plates all look fine and rust free I will check the rest of it at the weekend I’ll take both wheels off check for tightness on every bit and bolt I find
Matt
Matt
2004 E85 Z4 2.2i Titan Silver
