Been on and off for a while now . Sometimes it can go clear for months but finally seems to be staying on , the handbrake light yellow and the yellow triangle .
Ran it through carly a week ago and was geting a wheel sensor fault on front left . Changed that tonight but now im getting this .
Fault Code: 005E20
Fault Explanation::DSC-ECU: ECU-internal: General ECU error. / DSC ECU: ECU internally: General ECU error --- (DSC: controller internal) / Pressure sensor 1 are electrically defective. / DSC-ECU: General ECU error. / Pressure sensor on the front control circuit electrically defective / Coil inlet valve (ISO) Left Front overtemperature
Now is one of the two sensors on the master cylinder ? or is it the dsc pump .
Any help would be appreciated , thanks
2 yellow lights abs fault
- Behr
Seems to be a lot of this going around right now.
There’s one or two recent threads on this in this very section. Suggest you have a further read, but yes, it does seem to be the DSC sensors that are the usual culprit.
Does the software that you have allow you to view the live values from each sensor? INPA and DIS do if you have access to either?
"It's got red seats and the roof comes off. What's not to love?"
- williamdefender
Im using carly but think i purachse the inpa from ebay a couple of years ago . Will check that to see if i can get live values as im not getting them carly . Will have a play and see how i get on ,
- ph001
Do both pressure sensors first. They are cheap and easy to change
- williamdefender
Changed the front pressure sensor today only and carly was able to clear down the fault . Looks to be holding . Happy days
- ph001
