Now I'm not saying the interior never rattled before, as it does...All the time!!! Anyway, just went for a drive with the radio off and noticed the passenger side A-pillar interior cover is now making a slight knocking noise.
I can't put 100% blame on the autoglass fitter as I quickly removed my dashcam wiring before he turned up and I never noticed it on my drive to work yesterday as the roof was down.
Can the interior covers be removed easily? I've never had it off before. I stuffed the dashcam wiring down the side of it, so it was hidden, albeit not perfectly.
A quick Google image of the cover I'm referring to:
Interior rattle after having windscreen replaced.
- ben g
- ph001
Yep, fairly straightforward. You have to remove the horizontal trim piece above the windscreen first - do this by removing the sun visor screws and it will all just unclip (interior courtesy light just pops out easily with a flat blade).
With the top trim removed, the side trims just pull out and upwards. They are just on the usual crappy clips.
I found using the 'furry' part of self adhesive velcro the best thing for squeaks and rattles.
- ben g
Thankyou, will give it a go at the weekend. Knowing my luck, the plastic will break
Just don't break the screen
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
