Getting desperate!!
Jamo96
Getting desperate!!
Post by Jamo96 » Sat May 05, 2018 4:12 pm
Do the pressure sensors have different part numbers or are they both the same? Will get that sorted asap, few other jobs then hopefully get it through the mot! Appreciate the help
2003 2.5i Sterling grey E85 manual, black leather interior,
IAmOrion
Getting desperate!!
Post by IAmOrion » Sat May 05, 2018 4:15 pm
Jamo96 wrote: Sat May 05, 2018 4:12 pm Do the pressure sensors have different part numbers or are they both the same? Will get that sorted asap, few other jobs then hopefully get it through the mot! Appreciate the help
They're both the same. Just order 2 of the items posted an eBay link to :) £54 posted (for 2) is pretty good IMO and it fixed mine
(I too had the yellow handbrake and DSC light)
There are cheaper (and more expensive) versions, but I went for them as someone else recommended them to me.
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
Behr
Getting desperate!!
Post by Behr » Sat May 05, 2018 6:37 pm
I have the same symptoms at the moment. I plugged into DIS and confirmed an implausible signal from the DSC sensors was the cause. I haven’t got around to changing them out yet but may look at the ebay ones.
"It's got red seats and the roof comes off. What's not to love?"
Rosscuthill
Getting desperate!!
Post by Rosscuthill » Wed May 09, 2018 9:07 pm
I had the dreaded three lights on last year. After some research I found out that the most likely cause was the ABS pump/ecu, checked BMW prices and nearly had a heart attack. Howerver I located a company colled BBA Reman which recondition these units for a fraction of the cost. Took the chance and ordered one, got it fitted and ... problem solved. If your handy with the tools and know how to bleed your brakes its not too difficult to replace.
Saved myself an absolute fortune
dans6490
Getting desperate!!
Post by dans6490 » Wed May 23, 2018 7:56 am
Bookmark
Silverfox
Getting desperate!!
Post by Silverfox » Mon Nov 05, 2018 8:50 pm
Hi,
I need to replace my brake pressure sensors and I am interested in how you find the ones you purchased on eBay, would you recommend them? They certainly look good value :thumbsup:
Regards,
Andy
2.0i SE, black leather, 108's, Alu stubby, Stainless Steel tail pipe
IAmOrion
Getting desperate!!
Post by IAmOrion » Mon Nov 05, 2018 8:56 pm
Silverfox wrote: Mon Nov 05, 2018 8:50 pm Hi,
Regards,
Andy
Well it’s been about 6 months since I fitted mine that were from eBay (there’s a link in one of my previous posts) and without jinxing it, everything is still perfect :)
IN CAMBRIDGE CB22
Silverfox
Getting desperate!!
Post by Silverfox » Mon Nov 05, 2018 9:14 pm
Thanks IAmOrion , that's good to know, on that note I will looking at getting a pair of the same from eBay I recon. :thumbsup:
