Flat battery now steering issues...NO MORE
This morning I jumped in the Zed and got a very slow engine turn over on the key. I attached my charger and used the MR2 to go to the AV8 meet.
I got home and just tried the Zed and it started OK, but now there is a light with a steering wheel and an exclamation mark, on. The steering is really heavy now. What has happened ??
Any suggestions
Any suggestions
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- mr wilks
Help Flat battery issues
Sounds as if a low battery as triggered the fault mode on steering column .
Unless battery is goosed ( or alternator isn't functioning correctly ) then a trickle charger should liven the battery & consequently the steering should return to normal , , unless its start of the dreaded failed / sticky steering wheel motor
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Will it hurt if I undo the battery terminals and try and re-set something on the car ??
It was working fine last weekend, so not sure if a light had been left on somewhere which drained the battery ?
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- ph001
Yes you can disconnect the battery and short the leads together to try to reset it. I would be buying a new battery if I were you though.
Thanks, a forum member is having a look tomorrow, so hopefully we will know if the battery is Ko'd, got it charging at the moment. Fingers crossed
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- kis
I've got one of those stand alone chargers. Happened to the Zed once, wasn't using it that often then went on holiday and was dead upon return. Disconnected and charged up inside overnight and re-installed the following morning, all good. Still going strong a good few months later. Not sure what sort of charging system you're using? Maybe a good solid charge will sort?
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
I have a Ctek and a normal charger, It was still on this morning when I checked, I didn't start the car though. bladeowner is coming up to have a look, fingers crossed.
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Help Flat battery now steering issues
OK, so we connected Carly and ista. They show 'No comms with electric power steering'. Also noticed that the sports button is not lighting up. Steering is heavy, checked the relevant fuses which all look good. There have never been any problems with the steering.
Any advice gladly welcomed
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Sounds typical of a dead EPS motor
- ph001
...or the ECU that controls it. ECU testing will sort it out for you... http://www.ecutesting.com/common-faults ... ng-problem
Indeed, this is what I meant to say! Generally if there's no communication it's because the ECU has gone in the motor, luckily it's a reasonably easy fix for a company such as the above.ph001 wrote: ↑Tue May 01, 2018 10:21 am ...or the ECU that controls it. ECU testing will sort it out for you... http://www.ecutesting.com/common-faults ... ng-problem
Thanks, I was hoping it wasn't that but it does sound like it is. I thought I would have experienced some problems before hand, but nothing at allmjennings23 wrote: ↑Tue May 01, 2018 10:30 amIndeed, this is what I meant to say! Generally if there's no communication it's because the ECU has gone in the motor, luckily it's a reasonably easy fix for a company such as the above.ph001 wrote: ↑Tue May 01, 2018 10:21 am ...or the ECU that controls it. ECU testing will sort it out for you... http://www.ecutesting.com/common-faults ... ng-problem
Just searching the forum for more info.
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- 2dogs
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I have spoken to a friend of a friend who is an auto electrician, he agrees that it seems weird why the steering control has stopped working after a flat battery, so will have a look, hopefully at the weekend.
If this shows a problem with the steering ecu, I will be sending off to ecu testing.
What sort of job is it to remove the motor and ecu.
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
