Trouble with roof
Trouble with roof
Hi all
A friend of mine was having trouble with the roof on his 53 plate z4, so he did what was said in his manual to get roof down, pull red lever in boot and pull the cord in boot, but now the motor moves slow and struggle to work, by him pulling red lever would this do any damage ?? All help please
- Phoenixboy
Trouble with roof
have a look on the forum services section for people in your area or closest.Markben wrote: ↑Sat Apr 28, 2018 2:42 pm Hi all
they are the roof gurus and will sort it at a reasonable price.
E89 s drive 30i manual/gone
space grey
Carbon interior trim
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Gone, E85 Ruby Black.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
- MACK
Trouble with roof
First of all if you didn't put the red lever back to its original position the roof motor wont work as the bypass will still be active.
The real question though is what was the issue with the roof in the first place that led you to use the roof motor bypass?
Silver 05 3.0i SE
White E89 20i M Sport
Trouble with roof
Hi the roof was ok before, it unlocks and moves about 3 inches then will not move at all,
Trouble with roof
Where Bouts are you /he based? As Rob said there's plenty of people dotted around who can sort it
18 Z4s owned to date.
Current: 2.5i Titan silver
- Number5
Trouble with roof
Your nearest roof specialists are probably either me in Bristol , or Ducklakeview in St Helens (Merseyside way).
Drop either of us a PM if you want us to look at it.
I would say that the bypass valve is probabaly half in half out if its moving slowly. If you leave it half way up, does it hold there or does it drop back down with gravity within 30 seconds ? If it drops, your bypass valve is allowing the pressure out and not sealing the system. Easy fix once the motor is out and accessible.
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Trouble with roof
Hi
It has just worked perfect up and down a couple of times, then it just open the locks and will not move back at all, only open and close the locks,
- MACK
Trouble with roof
By locks I take it that you mean the latches at the front of the roof, not the ones in the doors
If that's right then this sounds like classic main roof motor failure. The front motor unlatches the locks on the windscreen but then the main motor fails to kick in and actually lower the roof.
It's easily sortable. A few members do it a few different ways. If I was you I'd give number5 a pm
Silver 05 3.0i SE
- Number5
Trouble with roof
if it's frequently still working it sounds like the perfect time to relocate it before it dies completely. " A stitch in time saves nine.." as they say.
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Trouble with roof
Hi all
Got the roof off over the weekend , to find the roof pump and motor housing full of water, someone said to relocate motor in the boot, is it a easy job to do. Tested motor on battery and don’t move it got rusty water around it. Advice most welcome
- tug
Trouble with roof
Hi Mark, when you connect the motor to the battery directly does it work at all?
E85 N46 2.0i SE BLACK SAPPHIRE
- ph001
Trouble with roof
Submerge the motor in a bowl of diesel for a few minutes giving it a few taps. Then try again on the battery. They usually spring to life.
- Ducklakeview
Trouble with roof
The washing in diesel is only a temporary fix if it works as the commutator will have corrosion on it. When the motor stops with the brushes on that corrosion it won't start again without a nudge. Stripping the motor and refurbishing the commutator makes them work like new again, every time. And yes, I speak from experience.
Mike
Mike
- tug
Trouble with roof
Exactly what i was gonna say buddy But as Mike says they dont last long but it is nice to see them coming back from the dead even if only for a short while.
Cheers, tug
