Looking at a 2500 EUR fix... Steering column went crazy on me...
Daaaaan
Post by Daaaaan » Tue Jun 19, 2018 11:29 am
wonkydonkey wrote: Mon Jun 18, 2018 5:55 pm Okay so the ribbon repair IS the torque sensor repair, which could tie in nicely with your test failure reports.
Have a look Daaaaan: viewtopic.php?t=82880
Is the torque sensor another sensor I was not aware of?
Besides the ECU I thought there was only the steering angle sensor... Where is the torque sensor located?
2008 Z4, 2.0i, white with black roof. Cupholders: check. Proper "313"s: check. Wind-deflector: check.
Dorin
Post by Dorin » Tue Jun 19, 2018 11:42 am
Salut,
sint Dorin din Bucuresti si am un z4 E85/2007.
Pentru problema ta ,daca nu ai rezolvat o,mergi in comuna Tunari, la Autoroller .
Au niste baieti super calificati si cu siguranta iti vor rezolva problema.
Zi buna
wonkydonkey
Post by wonkydonkey » Tue Jun 19, 2018 12:11 pm
Daaaaan wrote: Tue Jun 19, 2018 11:29 am Where is the torque sensor located?
The thread I linked you to answers your question with lots of pictures and even more words.
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
Daaaaan
Post by Daaaaan » Tue Jun 19, 2018 12:42 pm
Thanks a lot for the tips guys. The ECU just arrived back from ECUtesting.
I'll try the solution in that thread these days...maybe that ribbon got damaged when my local car guy replaced the steering angle sensor 2 weeks before problems started?
wonkydonkey
Post by wonkydonkey » Tue Jun 19, 2018 1:13 pm
Good luck, and let us know how you get on 😊
Previous:
<My name is James>
alane29
Post by alane29 » Tue Jun 19, 2018 8:23 pm
Getting to the ribbon is a ball ache (technical term) and very time consuming not to mention fiddly and its not guaranteed to be the issue, i stripped the column down to its component parts to get to the ribbon only to find the ribbon was intact .
I have since converted the car to hydraulic steering
Looking at the ribbon its not easily damaged considering the steering wheel only goes round about 4 turns there is enough ribbon for it to go round about 10 times
2007 E86 M Coupe
2005 E85 2.5SE
Daaaaan
Post by Daaaaan » Wed Jun 20, 2018 2:18 am
But what was the issue with your steering? Did you manage to get to the bottom of it and find the source of the problem, or did you just replace it?
alane29
Post by alane29 » Wed Jun 20, 2018 6:11 am
Issue was definitely the steering,the steering light was on and no power steering
i just replace it with hydraulic steering from an E46 this was the second time i had steering issues and to be honest was at the end on my tether with it .was a toss up between selling the car or doing a permanent fix but as i owned the car from new in 2005 i was kinda attached to it .
1st time issue was with the motor 2nd time never found out what was causing it :headbang:
2007 E86 M Coupe
2005 E85 2.5SE
mjennings23
Post by mjennings23 » Wed Jun 20, 2018 10:40 am
Same for me, but the steering only failed when you turned left so clearly something had worked loose or similar. Error was 611C, which points to the torque sensor on the column rather than the ecu or motor.
As such, I removed the pinion gear from my motor and left the casing in place, maintaining the use of sport mode for the throttle as the BUS systems are still communicating fine.
The swap to hydraulic is reasonably easy in honesty, the hardest bit was routing the hoses in a suitable way, had to sort out a support too to keep the radiator return coolant hose away from the pump pulley, as its a good bit larger than the idler pulley you replace.
Daaaaan
Post by Daaaaan » Mon Jul 09, 2018 10:37 am
My local guy just stripped the torque sensor down to the last bit, as per the instructions given in the link a few posts back. I have the same error code as the guy that did the tutorial, but my problem isn't there.
The strip was taken out as much as it would go, around 1m, and no broken wires were found, wires were tested with an electrician's measuring tool for continuity and also for resistance (don't know the name of the device in english, it's a basic electricians' tool)
Below are the photos. I am stumped.
Is there anything else I can do? Please help, any feedback is gteatly appreciated...I can't believe I have to spend 2500 EUR on a brand new steering column...my car only has 100k km and it's from 2008!!! :cry: :cry: :cry:
