I have an oil leak on my 2006 2.0 engine but I’m not sure where it’s coming from or if it’s going to be a fix or replace I have a pic taken when the car was up on a ramp from under the car. Does anyone know what part the oil is leaking from and an idea of cost to put right.
Oil leak but from where ?
2.0 sport Phoenix yellow
- jabber
That oil looks suspiciously new any chance its from a spill?
Z less again
Thanks for the idea but no have not put any oil in it
- eleflo
it looks like the vacuum pump, had the same, there is a rubber seal inside, I replaced it and ran sealer round the inside and it did cure it for quite a while but I needed to renew the whole pump in the end, got one on Ebay for £50 ( there is a couple available now) think the are a lot dearer from the Stealers.
wrong roof, 2 pots short, stubby, wrong exhaust, no heated seats, but I luuuuv it, Now all gone to a new home
Thanks eleflo I did have it in a garage some time last year but I forgot what they said it was as I only use it in summer time and it’s been locked away for some time since then, I do remember them saying £500 will fix it but thought I would ask on here with all the knowledge.
- eleflo
Your Welcome, they are very easy to fit so I did mine myself, so give it a go
