Maybe someone should point out that the TS has a 168k diff according to the ETK?
It's definately not a 1:1 swap, maybe it can fit with some extra work, maybe not.
Replacing diff
- GuidoK
Replacing diff
Replacing diff
https://www.dropbox.com/s/fdj5h0nnkd40g ... 4.mp4?dl=0
Video of issue, try and put any acceleration on the car and you get a horrible graunching noise and jerking of road wheels which eventually causes DTC, ABS and traction control lights on
Turn off DTC and its drivable with normal acceleration but sounds like something is knocking underneath????
Merlot 2.2i SE, so far new discs and pads, seats replaced, Cam cover replaced, Roof now fixed, new diff x3, new halfshafts, new drop links and other bouncy bits,
Replacing diff
Another question on the diff....
Ratios......
The one in my 2.2 is a 3:45 I've found a 2.5 with 3:23 so does that mean it'll be longer in the gears tban a 3:45?
If so a 3.0 diff seems a better bet with roughly the same ratio and loads on eBay at the moment
Ratios......
- Uncle_Gravy
Replacing diff
Sorry to hi-jack, just want to simply add some knowledge to my mind bank.
What are the benefits of adding something like a quaife lsd to a 3.0i?
