Knocking, judder vibration from rear
Decided to take the Zed to work this morning, heard a knocking from rear thought it was probably the exhaust but when I pulled on to dual carriageway horrible vibration and knocking from what sounds like nearside rear and worse as you got faster, so sat at 40 and let the world past me
The car has been sat in the garage for six months so maybe that has something to do with it
It doesn't appear to be during acceleration so I'm thinking wheel bearing, but don't they drone?
Cheers in advance
Cheers in advance
Merlot 2.2i SE, so far new discs and pads, seats replaced, Cam cover replaced, Roof now fixed, new diff x3, new halfshafts, new drop links and other bouncy bits,
I had this on my old z4 coupe. Made an awful noise turned out to be a massive egg on the inside of the tyre!
18 Z4s owned to date.
Current: 2.5i Titan silver
^more specifically if it's been sitting... flat spotted tyres. Low profile with flat spots are horrible at speed.
MR-2 Turbo Rev2
Yep no Z yet. On the hunt.
The nearside tyre is brand new but I'll check the others
Could it be corrosion on the disc, or has it been parked with the handbrake on for a long time so that it’s left crap on the drums that rubbing?
I left the handbrake off and took her out for test drive prior to the MOT and all was well then
I'll jack the back end up and give the wheels a wobble to see if anything going on there.
Wheel nuts all done up tightly if it had a new tyre fitted ??
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
My egg was on the inside of the tyre. Take all wheels off and have a good nose
Got home eventually chucked her in the garage and jacked up the rear end
No play in the wheels,, both tyres look fine, off side has a bit of a buckle but nothing major, there's a retaining spring missing off the offside caliper so they're rattling a bit
Worst part is when I started her and stuck her in gear with the road wheels off the ground that's when the noise kicks in when the when you put drive on the wheels, a graunching noise from the offside rear, not all the time maybe every half revolution but at 40-50 it would be pretty much continuous
Any ideas, driveshaft, diff?
Stick your head under the car with the wheels turning. Be careful though, axle stands etc. Try to locate where the noise is coming from.....nearer the brake side or the centre diff section. Try to pin it down further before dismantling anything.
If you are anywhere near chesterfield, you are welcome to put it on my lift.
Andy.
Andy.
- ph001
I wonder if it could be anything to do with the drivetrain between the gearbox and the diff... viewtopic.php?f=3&t=97640&hilit=Donut&start=15
Doesn't sound it, I have no clunk just the horrible graunching and vibration, I'll have to leave it till the weekend now and force the poor old Alfa GT back into service, poor thingph001 wrote: ↑Wed Apr 18, 2018 9:36 pm I wonder if it could be anything to do with the drivetrain between the gearbox and the diff... viewtopic.php?f=3&t=97640&hilit=Donut&start=15
Bloody typical first decent day we get and this happens
Update
Had some time on her today
Started up and stuck in gear, on axle stands as soon as you put any sort of throttle on the revs drop the graunchy something's broken noise like metal rubbing together happens and when I watched the road wheels the graunching coincides with the nearside rear wheel kicking up, so I'm looking at driveshaft or diff I think
Hi Wafoo,
I have the same symptoms and also feel it could be the diff. I went around a corner +- 90kmph and also got a slight lock up.... apon deacceleration I also get a slight wirling sound from the same side as the vibration and lock up, the left rear.
Please let us know what the issue was in the end.
Thanks,
Seb
Thanks,
Seb
OnlineArgyll Andy
Seb, Wafoo hasn’t been on the forum since 2018 so don’t think you’ll be getting a responseSebT wrote: ↑Mon Jun 21, 2021 6:08 pm Hi Wafoo,
Thanks,
Seb
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
