Engine coolant change
Puggsley2
Post by Puggsley2 » Tue Apr 03, 2018 10:52 am
My E85 - Z4 has around 90,000km on the clock and although the oi and brake fluids have been change frequently the coolant has not. Anyone know the recommended periods for changing coolant?
highway1
Post by highway1 » Tue Apr 03, 2018 4:41 pm
Coolant changes are recommended every 3-4 years.
People get hung up on its "anti-freeze" abilities and so leave it unchanged for years and years because the tester says its ok down to minus 20 or whatever but the corrosion inhibitors within it, loose their effectiveness- which is not good!
Even if you're not changing it yourself, its a cheap garage job.
Wafoo
Post by Wafoo » Wed Apr 04, 2018 7:45 am
Easiest coolant change I've ever done in my Zed took 10 mins tops
Merlot 2.2i SE, so far new discs and pads, seats replaced, Cam cover replaced, Roof now fixed, new diff x3, new halfshafts, new drop links and other bouncy bits,
Puggsley2
Post by Puggsley2 » Thu Apr 05, 2018 1:30 am
Many thanks Guys. You have answered my question. Not sure how to change it in 10 minutes though.
Mike6
Post by Mike6 » Thu Apr 05, 2018 5:56 pm
I just suction coolant out from the header tank and then replace every year. That way there is a continual change of coolant. Make sure you buy the BMW stuff and dont mix with other makes.
mjennings23
Post by mjennings23 » Thu Apr 05, 2018 9:02 pm
An alternative to the BMW branded stuff is G48 based coolants. I personally use Comma. Its identical to the stuff the dealers use in spec, I believe Comma are even the supplier or have been previously.
Puggsley2
Post by Puggsley2 » Fri Apr 06, 2018 9:19 am
Thanks to all for the advice. I just changed the coolant with no problems. I couldn't match Wafoo's time though, it took me nearly 30 minutes.
mjennings23
Post by mjennings23 » Fri Apr 06, 2018 5:07 pm
Couple of hours here, but that included changing the pump, stat, hoses and tank. Whoever decided to put a vertical part of the crossmember directly in front of the waterpump on the M54, makes a simple job into a 'lift the engine' state of affairs :thumbsdown:
Wafoo
Post by Wafoo » Sat Apr 07, 2018 7:47 am
Puggsley2 wrote: Fri Apr 06, 2018 9:19 am Thanks to all for the advice. I just changed the coolant with no problems. I couldn't match Wafoo's time though, it took me nearly 30 minutes.
It was a Wafoo 10mins, it has a 300% error factor, it was a doddle though wasn't it
Puggsley2
Post by Puggsley2 » Fri Apr 13, 2018 6:49 am
Houston we have a problem. During the fluid change I did not change the plastic plugs, mainly because I forgot to buy them. All went well but after a couple of days the low water warning light activated. Somewhere around 1 litre of fluid had been lost, presumably while driving. I now have new plugs but the one in the radiator comes with it's own sleeve (see photo)
and I have no idea how to remove/replace the sleeve. What I thought were screw threads are not. I can turn the hex approx 60 degrees but no more. Do I just pull it out? I don't want to break anything that will cost mega dollars to fix
Puggsley2
Post by Puggsley2 » Fri Apr 13, 2018 8:47 am
As a supplementary I refilled the radiator and ran the engine at low RPM until the temp alert sounded. Loosening the filler cap just released coolant which suggests to me that the radiator is not feeding into the engine block. The hoses are mad hot though. Any suggestions before I pull more hair out?
ph001
Post by ph001 » Fri Apr 13, 2018 9:50 am
What engine do you have?
Puggsley2
Post by Puggsley2 » Sat Apr 14, 2018 1:01 am
2.5 litre E85
srhutch
Moderator
Moderator
Post by srhutch » Sat Apr 14, 2018 9:50 am
Puggsley2 wrote: Sat Apr 14, 2018 1:01 am 2.5 litre E85
Pre or post facelift, as it could be an M54 or N52 engine.
Puggsley2
Post by Puggsley2 » Sun Apr 15, 2018 12:40 am
The car is a 2005 model which I presume is pre facelift. (In fact I've never had one). Going off the VIN I'd say the engine was N52. The good news is that I think I've fixed the problem. After couple of days driving the car I felt so confident that I re-fitted the belly plate. Now I can move on to my wife's Honda.
