Have I just fried my ECU?
- Z4 Gaz
Was just using a C110 scanner to clear some air bag codes.
Exited back out of the options, so it wasn't in the middle of doing anything, however I forgot to turn the key back to the off position before pulling the cable, now the car wont even turn over.
Have I just fried the ECU? If so how much pain am I about to be in?
E85 3.0i
- Smartbear
What happens when you reconnect your scanner, does it communicate with the car?Z4 Gaz wrote: ↑Tue Mar 20, 2018 3:37 pm Was just using a C110 scanner to clear some air bag codes.
e85 3.0si sold
- pvr
If all fails, remove the negative lead from the battery, wait a few minutes, reconnect.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Z4 Gaz
Still communicates ok.
Tried removing the batt. connections.
I should add I hadn't run the car in a week or so, so am now wondering if the battery has gone dead, will put some charge through it and report back.
Fingers crossed.
Fingers crossed.
E85 3.0i
- pvr
How long did the programming take? Having the ignition on for 15+ minutes would drain the battery as well.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Z4 Gaz
Not that long.
At the moment when I try and start the car I just get a clicking noise from the engine bay. Going to let it charge for 30 minutes then try again.
Everything like windows still work, lights, sport button illuminates and goes out when pressed still.
E85 3.0i
- pvr
Sounds like a dead battery then.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Z4 Gaz
Weird if it is, as I worked out it was actually only 4 days since I last had it running. Before that it would sit for a few weeks and start no problem, and started perfectly 4 days ago.
E85 3.0i
- pvr
They take a hell of a hit on a 3.0 trying to start it, mine did not even turn on an emergency battery at all.
If you have parked it for 4 days, and you were programming with the ignition on, that can cause a lot of drain.
When you describe that everything works, but not the starter, that is exactly the symptom of an empty battery.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Smartbear
This freezing weather knocks the bejeezuz out of the battery as wellpvr wrote: ↑Tue Mar 20, 2018 4:16 pm They take a hell of a hit on a 3.0 trying to start it, mine did not even turn on an emergency battery at all.
e85 3.0si sold
- Z4 Gaz
It lives, hurrah.
Now I just need to figure out why I can't get rid of code 9891 as I have an occupancy emulator fitted.
Edit, it wasn't pushed in properly, all fixed, car not ruined, result, thanks guys.
E85 3.0i
- ph001
What did you do to get it to fire?
- Z4 Gaz
Just charged it for 30 minutes.
Think the battery might be the original, so could probably do with changing it being 15 years old
E85 3.0i
- Z4 Gaz
Tried to start the Z just now and it only just fired on its second attempt.
Checked for a battery drain and that came back all good, settling at 0.02A
Looks like the battery has totally died over the last few days of cold weather without any warning. Got a new one on its way.
E85 3.0i
- ph001
I'm sure that will sort it.
