Trying to install Aux and failed.
Vbstein
Post by Vbstein » Sat Mar 17, 2018 3:00 pm
Hi
I tried to install the aux cable on my 03 z4, after installing however the stereo doesn't pick my aux cable.
Could this be to using a ebay cable?
BMW Z4 3.0I is old but not obsolete.
pvr
Post by pvr » Sat Mar 17, 2018 3:12 pm
Does your stereo show the Aux input as an input source? If it does, then it is at least connected properly.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Vbstein
Post by Vbstein » Sat Mar 17, 2018 3:15 pm
Nope and I have tried disconnecting and trying to plug in again
pvr
Post by pvr » Sat Mar 17, 2018 3:25 pm
Ok, so you are talking about the quadblock fill ins at the back of the radio I assume? The radio recognises these as soon as they are plugged in (irrespective of whether there is anything connected to the 3.5 mm connector on the other side).
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Mikeyay
Post by Mikeyay » Sat Mar 17, 2018 3:47 pm
I had the same issue with a cheap one off eBay, bought a proper one from Fruity Car Cables and it works a treat!
2.5si Sport Titan Silver
mr nurburgring
Post by mr nurburgring » Sat Mar 17, 2018 7:34 pm
I had this problem, I knew that a 5£ one off eBay wouldn’t work, but, you can add the needed capacitors and one resister to the cable and it will work perfectly, cost about 30p for the bits from maplin or an electrical shop and takes about 10 mins to do.
I did this a couple of weeks back.
ben g
Post by ben g » Sat Mar 17, 2018 10:25 pm
Mikeyay wrote: Sat Mar 17, 2018 3:47 pm I had the same issue with a cheap one off eBay, bought a proper one from Fruity Car Cables and it works a treat!
Get the one this guy recommended from fruity car cables. It's works
Vbstein
Post by Vbstein » Sun Mar 18, 2018 1:18 pm
I have no idea how to do that :(
I bought an more expensive one from amazon still same issue
pvr
Post by pvr » Sun Mar 18, 2018 1:39 pm
You are putting it in the right place in the quadblock, right?
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Vbstein
Post by Vbstein » Sun Mar 18, 2018 4:40 pm
Yep just under the main quad connection as there's nowhere else to fit it.
I did this with a previous Z4 from 06 and had no issues however this 03 Z4 isn't playing ball
Mighty1
Post by Mighty1 » Sun Mar 18, 2018 5:51 pm
No expert here but I’ve recently had same problem I bought the quad block from bmw Durham very helpful service manager it was £63 but with a guarantee of a refund if it didn’t work also checked via internet that it was correct part as some didn’t work
Although an Audio guy fitted it costing 40 quid it worked first time point I’m trying to make is I’m sure he pulled out another block and this was fitted in the top left I believe worked straight away after unsuccessful attempts trying to fit a different make
Hope this is of some help
Geoff
Previous
Z4 2.0 M sport
Porsche Boxster
SLk 3.5
MK1 Mx5
Currently z2.5 Auto exclusive Maldives blue
Ducklakeview
Post by Ducklakeview » Sun Mar 18, 2018 7:46 pm
The cable needs to have a resistor wired into it in order for the head unit to detect it's presence.
Jamie got one a few months ago for a few quid from ebay that worked.
Mike
MJJamieson
Post by MJJamieson » Sun Mar 18, 2018 7:49 pm
Must have resistor and isolating capacitors as per diagram.
2004 E85 Z4 2.5i SE Sterling Grey.
ben g
Post by ben g » Sun Mar 18, 2018 7:57 pm
Buy this one and it will work, guaranteed.
https://www.ebay.co.uk/itm/BMW-Z4-E84-E ... 1066788151
Ducklakeview
Post by Ducklakeview » Sun Mar 18, 2018 10:28 pm
ben g wrote: Sun Mar 18, 2018 7:57 pm Buy this one and it will work, guaranteed.
Sure Jamie paid a third of that for his and it worked fine..
Mike
