Couple of issues after battery disconnect
ph001
Post by ph001 » Tue Mar 20, 2018 8:54 pm
greg81 wrote: Tue Mar 20, 2018 8:44 pm Not sure exactly what this means but I've read you can recalibrate your steering angle sensor?
You can, just like I said above! The pressure sensors are the ones on the master cyclinder unit. Easy enough to change once access is sorted. The dds is deflation detection system so thats the one causing your tyre pressure warning. Would seem a little odd to be a button fault.
I’m still not convinced any of them are genuine.
I’d be clearing all these codes and reseting steering angle in INPA and then see if any re-appear.
greg81
Post by greg81 » Tue Mar 20, 2018 10:50 pm
ph001 wrote: Tue Mar 20, 2018 8:54 pm
That'll be where I read it! I have a terrible memory.
What makes you think they're not genuine?
I need to get sorted with a decent diagnostics/programming tool at some point but skint right now. I'll need to live with these in the short term but will update here when I get some money together!
ph001
Post by ph001 » Tue Mar 20, 2018 11:33 pm
Well, it would seem rather a coincidence that all this stuff just went faulty when you reconnected the battery.
greg81
Post by greg81 » Thu Mar 22, 2018 9:57 am
ph001 wrote: Tue Mar 20, 2018 11:33 pm Well, it would seem rather a coincidence that all this stuff just went faulty when you reconnected the battery.
That's fair, and I hope you're right :)
I will update as soon as I have any more info!
Thanks again
greg81
Post by greg81 » Sat Apr 14, 2018 7:42 pm
Quick update here. I've bought myself one of the cables from bcables and software so will be able to check and clear the code soon.
Oddly enough the electric windows seem to have completely sorted themselves out. I did try a reset a couple of times to no avail, bit noticed this week they work correctly now.
'the feck?
greg81
Post by greg81 » Mon Apr 23, 2018 10:22 pm
Finally got hold of INPA and had a read/clear of codes.
Apologies for the mix of german/english - I've translated the important bits (I think)
First code which will explain the DSC light. This code will not clear. I'll need to work my way around INPA to try and reset the steering angle.
Date: 23.04.2018 21:46:55 ECU: DSC_MK60 JobStatus: OKAY Variant: DSC_MK60-------------------------------------------------------------
RESULT: 1 error in error memory !-------------------------------------------------------------
5E40 Steering angle sensor signal implausible, offset
Error counter: 4 Logistic counter: 40
Mileage 655350 km Fahrzeuggeschwindigkeit 0.00 km/h Bremslichtschalter 0.00 0/1 Bremsfluessigkeitsschalter 0.00 0/1 ASC/DSC_aktiv (Tasterfunktion) 1.00 0/1 Bremsdruck erkannt 0.00 0/1 ABS-Regelung 0.00 0/1 ASC-Regelung (BMR) 0.00 0/1 ASC-Regelung (AMR) 0.00 0/1 GMR-Regelung (GMR) 0.00 0/1 GMR-Regelung (MMR) 0.00 0/1 CBC-Regelung 0.00 0/1 MSR-Regelung 0.00 0/1 TDR-Regelung 0.00 0/1 SDR-Regelung 0.00 0/1 DBC-Regelung 0.00 0/1 RTA aktiv 1.00 0/1 Run-Up Mode 1.00 0/1
No matching error symptom test conditions satisfies errors currently present and already saved errors would cause the lighting of a warning light
Error code: 5E 40 E0 04 28 FF FF 00 0A 00 0C =============================================================
Next up from EPS...
Date: 23.04.2018 21:43:17 ECU: EPS_85_2 JobStatus: OKAY Variant: EPS_85_2-------------------------------------------------------------
6125 Error code 33: Lenkwinkelkorrektur
Error counter: 1
Mileage 105424 km Temperatur FET 26.00 Grad Spannung nach Relais 11.57 Volt Batteriespannung (Klemme 30) 11.49 Volt gemessene Temperatur FET 26.00 Grad Flag Zündung ein 1.00 0/1
No matching error symptom test conditions does not currently exist, but already saved errors would not cause a warning light to light up type No. 6: Too high
Error code: 61 25 20 06 01 33 7A 00 60 01 D0 01 CD 00 60 00 01 ============================================================
This was the full report. Again I've translated the error messages so they won't be perfect English. There's a couple that look related to an open/close button. I wonder if that's because GapTech is installed?
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 04/23/18 21:33:40 ECU: D_STVR2 JobStatus: --- - API-Job FsLesen: job status error - API-Job FsLesen: job status error
============================================================= Variant: CVM_IV 5 Error in error memory Error registration 1 : 0x0013: Control button ' Close ' permanently on GND <<<<!!! Error accurances: 10 Aussentemperatur 19.00 Grad C
sporadischer Fehler Error code: 13 0A 13
------------------------------------------------------------------------------------ Error registration 2 : 0x0021: VSW 4.2, undefinierter voltage range <<<<!!! Error accurances: 11 Aussentemperatur 22.00 Grad C
sporadischer Fehler Error code: 21 0B 16
------------------------------------------------------------------------------------ Error registration 3 : 0x0024: VSW V_ABGEL, undefinierter voltage range <<<<!!! Error accurances: 6 Aussentemperatur 22.00 Grad C
sporadischer Fehler Error code: 24 06 16
------------------------------------------------------------------------------------ Error registration 4 : 0x0012: Control button ' open ' permanently on GND <<<<!!! Error accurances: 8 Aussentemperatur 16.00 Grad C
sporadischer Fehler Error code: 12 08 10
------------------------------------------------------------------------------------ Error registration 5 : 0x0064: Canopy does not go on <<<<!!! Error accurances: 3 Aussentemperatur 4.00 Grad C
sporadischer Fehler Error code: 64 03 04
------------------------------------------------------------------------------------==================================================================================== Variant: LSZ_2 >>>>>>>>>> No error found <<<<<<<<<<< ==================================================================================== Variant: D_0066 -1 Error in error memory ==================================================================================== Variant: D_00E8 -1 Error in error memory ==================================================================================== Variant: D_0060 -1 Error in error memory ==================================================================================== Variant: EWS3 2 Error in error memory Error registration 1 : 0x000F: Power-On-Reset <<<<!!! Error accurances: 31
statischer Fehler Error code: 0F 3F
Error registration 2 : 0x000E: DME-Wechselcode XOR-Fehler <<<<!!! Error accurances: 4
sporadischer Fehler Error code: 0E 04
------------------------------------------------------------------------------------==================================================================================== Variant: LWS5_1B >>>>>>>>>> No error found <<<<<<<<<<< ==================================================================================== Variant: ZKE5_S12 4 Error in error memory Error registration 1 : 0x000E: Window lifter: Interruption of clamping protection strip or destandardization/error EKS-Electronics Beifahrertuer <<<<!!! Error accurances: 17
sporadischer Fehler Error code: 0E 11
------------------------------------------------------------------------------------ Error registration 2 : 0x000D: Window lifter: Interruption of clamping protection strip or destandardization/error EKS-Electronics Fahrertuer <<<<!!! Error accurances: 10
sporadischer Fehler Error code: 0D 0A
------------------------------------------------------------------------------------ Error registration 3 : 0x0033: Wiper: Blocked or Rueckstellkontakt <<<<!!! Error accurances: 3
sporadischer Fehler Error code: 33 03
------------------------------------------------------------------------------------ Error registration 4 : 0x0041: Diebstahlwarnanlage: Neigungsgeber <<<<!!! Error accurances: 3
sporadischer Fehler Error code: 41 03
------------------------------------------------------------------------------------==================================================================================== Variant: SZM46 >>>>>>>>>> No error found <<<<<<<<<<< ==================================================================================== Variant: KOMBI85 >>>>>>>>>> No error found <<<<<<<<<<< ==================================================================================== Variant: IHKA85 >>>>>>>>>> No error found <<<<<<<<<<< ==================================================================================== Variant: D_0068 -1 Error in error memory ==================================================================================== Variant: D_006A -1 Error in error memory ==================================================================================== Variant: D_00C8 -1 Error in error memory ==================================================================================== Variant: D_00F0 -1 Error in error memory ==================================================================================== Variant: D_00ED -1 Error in error memory ==================================================================================== Variant: D_003B -1 Error in error memory ==================================================================================== Variant: D_0048 -1 Error in error memory ==================================================================================== Variant: D_007F -1 Error in error memory ==================================================================================== Variant: D_00BB -1 Error in error memory ==================================================================================== Variant: D_0072 -1 Error in error memory ==================================================================================== Variant: D_00DA -1 Error in error memory ====================================================================================
############################################################### This content will stored temporary temporär in ..\inpa\sgdat\na_fs.tmp #######################################################
Just about all error codes cleared, but lights still on dash. I believe sorting the steering angle may sort that. Also worth mentioning that when accessing TPMS through INPA it errored saying there was no response from the control module.
Thanks,
Greg
greg81
Post by greg81 » Mon Apr 23, 2018 10:24 pm
Really need to work out how to run INPA in English! :(
greg81
Post by greg81 » Tue Apr 24, 2018 6:10 pm
So, yeah...
