Hard braking - Keeping her straight
Online
http://www.brembo.com/en/company/news/f ... mbo-brakes
Link should have some picture of hot hot brake discs all be it proper race cars but helps show the potential heat transfer.
Online
If it is the pad rubbing on the back of the piston and pad carrier part of the calliper a small amount of high temp Molykote grease should reduce or remove the noise if it is pad to disc try a different pad compound.
OnlineR60BBA
I’ve noticed that the noise only occurs when the handbrake is up (when jumping on the door sill in a stationary position). If I jump on the sill with the handbrake down there is no noise...
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- hopz121
Did you change the handbrake shoes when fitting the new discs?
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
OnlineR60BBA
I didn’t personally do the job so I don’t know. But I didn’t supply this part to the garage who did the work either so I presume not.
Why do you ask?
- cj10jeeper
Regardless of if you fitted new shoes you need to do a bedding in process when new rear disks are fitted.
Drive gently and hold the handbrake on firmly to slow the car while still driving. Do this for about 100m then repeat.
It cleans the inside of the disks and reseats the shoes.
You should never need new shoes unless you are harsh in use of handbrake or a rare failure happens
OnlineR60BBA
Just to clarify, do you mean drive slowly with the handbrake up? (If so how far up)? And how many times of 100m?cj10jeeper wrote: ↑Sun Jun 17, 2018 10:31 amRegardless of if you fitted new shoes you need to do a bedding in process when new rear disks are fitted.
- cj10jeeper
I thought it was clear aside the repeat that I'd do it 2 or 3 times. You are trying to work the brakes on the drum surface to heat them and bed in so you pull the handbrake hard enough to be dragging on the car, but keep the throttle pressed so it keep it driving.
OnlineR60BBA
I’ve just tried it.cj10jeeper wrote: ↑Sun Jun 17, 2018 11:05 am I thought it was clear aside the repeat that I'd do it 2 or 3 times. You are trying to work the brakes on the drum surface to heat them and bed in so you pull the handbrake hard enough to be dragging on the car, but keep the throttle pressed so it keep it driving.
It’s sort of worked, the squeak happens a lot less but is still there.
When the handbrake was applied and I pushed at low speed, it felt as if the bite on the nearside was not as strong as the bite on the offside.
The nearside squeaks whilst driving, so perhaps the nearside rear handbrake needs to be adjusted?
- cj10jeeper
Of course the handbrake needs adjusting. Done through a wheel stud hole, but easier to remove a wheel.
Once both are correct adjust the cable to get the wheels to bite at 3-5 clicks. Can’t recall exact number but around that.
OnlineR60BBA
How much on labour should I pay for this sort of job?cj10jeeper wrote: ↑Sun Jun 17, 2018 9:06 pm Of course the handbrake needs adjusting. Done through a wheel stud hole, but easier to remove a wheel.
- cj10jeeper
10 minutes per side, plus 10 to to adjust the cable. Add a bit for thinking and I’d say £30
In reality it should be part of fitting new disks
