No worries...all ideas are worth airing. It's only the N52 that has valvetronic - the OP has an M54 which is your more typical throttle flap.Scooba_Steve wrote: ↑Thu Mar 08, 2018 5:22 pm Mine was a hesitation but just throwing it out there. In normal operation the throttle is fully open with power controlled by lift and timing.
Loss of throttle response
- ph001
Didn't spot that! My bad, yes only the N52 has valvetronic. Still worth a shot if the throttle checks out ok, mine was only for about a second but was always at the same speed and throttle setting, codes did indicate a sticking solenoid though but didn't show EML.
If it would only happen in another gear, it would be pretty conclusive. Unfortunately 90% of the time I'm commuting at 55+ in 5th. When I get back from a company trip, I'll try to spend more time in 4th at around the same magic rpm point to see if I can coax it to happen. In the mean time I may try to buy the software to try to find if there is a intermittent dead spot on one of the pots. I assume I should be able to read the pot signals with the BCable software.ph001 wrote: ↑Thu Mar 08, 2018 5:08 pm Yeh, I don't think the OP would describe this as a hesitation at all. It's literally seconds of no throttle response whatsoever. Has to be lack of throttle actuator operation for one reason or another (I would place a very small bet on non-correlation of throttle pots on pedal).
- ph001
Yep, you can do that with INPA.
- Piper1
If it’s the actuator pedal module that I see here https://www.fcpeuro.com/products/merced ... 5426852644 would there be any type of programing like with getting a new throttle body?
03 Z4 2.5i
ESS VT1, Racing Dynamics SS headers ceramic coated, Full Super Sprint system, 4.10:1 LSD, K Sport BBK, Koni yellow/eibach combo, and lots of other bits
07 e86 3.0si stock for the moment
- ph001
Throttle adaptation reset should be all that is required
- Piper1
Just found this: https://www.pelicanparts.com/techarticl ... cement.htm
It was an interesting point at the bottom saying give it time for electronics to acclimate at idle or there’ll be a flat spot. My pedal looks like it might have been replaced prior to me owning it since the cover plug on the hold down bolt never was there. I have a new pedal to put in this weekend so I’ll let you know the outcome. I replaced the upper intake solenoid and it’s still doing what it has been so wasn’t that still have to do the lower solenoid just didn’t have time when I did the upper with juggling the kiddo around.
03 Z4 2.5i
This can occur after periods of constant speed if one of the tracks on the pedal actuator have a loss of signal due to dirt or wear, only once the system can verify the actuator position for both tracks (one the resistance increases the other it decreases)will it recover the signal and allow the ecu to know if the pedal is being depressed or released.
It can potentially get worse although once it becomes persistent it will give a fault code. and the engine will not respond at all.
Lost in space, found in a dustbin........
2005 Z4 2.2
2011 318 d Estate Recalled and repaired - Update: Turbo blown new one about to get fitted....
2008 2.0d Mondeo Estate Gone but not forgotten
2008 TDV6 Discovery 3 HSE
2005 Z4 2.2
- Piper1
OP have you had any luck yet? Took mine out of hibernation third day did it 3 times on the way home so I changed my pedal out and hasn’t done it for a week after so far.
03 Z4 2.5i
- ph001
Did you do a throttle adaptation reset?
- Piper1
I did when installing the new pedal. It still happened on the old pedal after the reset but with always driving in sport mode there was more going on then the throttle adaption doing its thing.
03 Z4 2.5i
- ph001
Do you have INPA? You can do a real time live data on the pot values with the pedal just with ignition on.
- Piper1
I have a Peake and the diagnostic software from ess that came with the vt kit. Still no codes showing. As an update it did it on the way in today so pedals not the problem. I noticed when it happened was when I was coasting in 5th going 70 slightly lifted foot and when I went to pressed on the throttle again it was like in a dead zone of acceleration. Down shifting revs went higher still no response and as I’m oscillating the throttle my boost gauge is going with my foot will go from vac -18 down to -2.3 but not to positive boost at all. The whole thing lasts a couple of seconds then back to normal.
Without codes now I’m at a loss. Think a possible sticky icv, or fuel pump/filter? I replaced the Disa about 20k ago when I first started noticing the problem when it was n/a so been happening pre f/i
03 Z4 2.5i
This is the first time you mention ESS fitted in the thread?
- Piper1
Ah well I had a thread a while back on it in the discussion part but since this started occurring least for me to take notice 20k or so on the clock before ess, was ruling any of the kit out.Scooba_Steve wrote: ↑Thu Apr 26, 2018 9:26 pm This is the first time you mention ESS fitted in the thread?
This was my original thread when I first took notice of it then totally forgot about it till th op in this thread revived it
viewtopic.php?f=3&t=52371&p=762876#p762876
03 Z4 2.5i
