B******s!!!!!!!
Wafoo
B******s!!!!!!!
Post by Wafoo » Mon Feb 19, 2018 12:02 am
Finally got round to getting the roof on today, fitted new hydraulic line (cheers Mike) moved motor to boot topped up fluid pressed up button, after a few moments whirr, whirr click she's alive up and down with awesomeness
Then up stop, whirr nothing, horrible smell of hydraulic fluid and a big puddle of fluid out of the right hand drain hole
Looks like another hose has gone.........
Oh well at least I know how to get the roof of now
Merlot 2.2i SE, so far new discs and pads, seats replaced, Cam cover replaced, Roof now fixed, new diff x3, new halfshafts, new drop links and other bouncy bits,
Mr Tidy
B******s!!!!!!!
Post by Mr Tidy » Mon Feb 19, 2018 12:10 am
Sorry to hear of your pain. :(
But as you say, at least you know how to do it now - hope the fix goes well. :thumbsup:
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
buzyg
B******s!!!!!!!
Post by buzyg » Mon Feb 19, 2018 1:02 am
Life's a learning curve. :wink: You'll crack it next time. :thumbsup:
Crazy Harry
B******s!!!!!!!
Post by Crazy Harry » Mon Feb 19, 2018 10:49 am
On the other hand that could be a result - a failure at the other end of the pipe would have filled your boot with hydraulic oil now you've moved the pump and that would have been a bu**er to clean. At least this way you've got a coating of oil protecting the drain area and a bit of detergent will disperse it off the floor :lol:
MACK
B******s!!!!!!!
Post by MACK » Mon Feb 19, 2018 11:11 am
I'm wondering if this could simply be you didn't seal/attach the new pipe properly so although a pain will be a cheap fix. Or that you also have a bad hydraulic ram. What happened to your original pipe OP, was it corrosion? If so I'm wondering if the ram suffered the same and although the pipe was initially the weak leak once replaced the ram became the weak spot.
Silver 05 3.0i SE
White E89 20i M Sport
Ducklakeview
B******s!!!!!!!
Post by Ducklakeview » Mon Feb 19, 2018 11:42 am
Driver's side bottom? That's normally the first to go... The fitting, which is mild steel, corrodes through as it takes a lot less water on that side to get it submerged.
I have a couple here.
You don't need to remove the roof to fit it.
Mike
Mike6
B******s!!!!!!!
Post by Mike6 » Mon Feb 19, 2018 7:05 pm
can you check that pipe from underneath the car or is it a requirement to be double jointed??
