Z4 2003 2.5i e85 not starting
Hi . Removed starter at it was only making a click noice and not starting, Need help!! the two small wires at the.back of starter one is black and the other is yellow and black, what is there function, if i put the ignition to start the black wire shows 12v and the yellow wire only only 2v what is the reason for this where can i look further.
- Gr3g4
Here is the wiring diagram for the starter if it helps.
Thank you. The one with 12 volt come from the ignition, the ews point has the low voltage 2v
You Dont perhaps have.the.diagram on e85 alternator connetions aswell please
- Gr3g4
Here you go.
This is all the help I can provide you with though. I'm not electrician unfortunately.. Maybe some other forum member can help?
- Gr3g4
One more thing. Is your engine M54? Then these apply:
Thanx wil help alot
- Gr3g4
No problem.
It seems my problems both leads to.the ews. So il need to do some obd2 fault finding
