MACK wrote: ↑Sat Feb 03, 2018 5:28 pmR60BBA wrote: ↑Sat Feb 03, 2018 5:19 pmMACK wrote: ↑Sat Feb 03, 2018 5:07 pmI'd be more concerned by the low fuel economy than one rolling road session. However the two together would imply an issue. That said is your fuel economy actually that bad. You say you've only had the car since September. It's obviously cold out there this time of year and if you're only doing short journeys the car will take longer to warm up hurting fuel economy over what the same car might achieve in the summer. Might be worth having it scanned to see if there's any soft codes in it that aren't flagging a warning light. That said plenty of parts can still be partially up the wall without a code actually being created but if they're miss reading power and emissions could be affected.
Only time will tell in regards to fuel economy and the weather.
Apart from fuel economy, the only ‘thing’ I’ve noticed with this car is that when I lift the clutch to the bite it makes a rattling/chattering sound after I’ve driven it hard. It doesn’t do this when the car is cold, or if it’s warm but hasn’t been ragged.
But the clutch is still strong so I don’t know whether it’s an issue or not.
Now that sounds like the dual mass flywheel and I wouldn't worry about that too much. Many manual cars suffer this and can carry on for many 10s of thousands of miles without it causing any issues. Usually you can just leave it till the clutch needs replacing. It wont be causing your lack of power etc.
I take it that as you havent mentioned it that the car runs smoothly and revs cleanly etc.
I too think it’s the flywheel.
Hopefully won’t keep the car long enough to fork out for a new clutch
The car is uber smooth, whether pushed hard or simply cruising. My cousin drives an A45 and says it delivers the power quite a bit smoother than his. I’ll probably take that with a pinch of salt but it’s still testimony to the engine’s overall smoothness.
Last week I managed to beat an E92 M3 off the lights in damp conditions, so I know it is capable (albeit at the next set of lights the driver admitted he couldn’t get full power down due to lack of traction and he was carrying a passenger.)
