Rattle/Vibration in engine (N52) when hot
- enzed4
Have noticed this for some time now, but haven't really followed up on it as it comes and goes.
When the engine has warmed up, say 15 mins drive or more, while stationery, if the engine is revved to around 1500rpm there is a rattling noise that sounds as close as I can describe as a vibration of something like a heat shield (sort of a 'tinny' sound) which tapers off a few hundred rpm above. It doesn't seem to make this noise when cold, and not every time when hot, though seems fairly regular. I tried to record it a couple of weeks ago, but the wife's iphone audio capture didn't really do it justice. Might have to try again to help troubleshooting.
I've looked up many lifter rattle noise videos, and this doesn't sound like it at all - it's not that ticking noise, and that's usually more obvious when the engine's cold, not hot.
Also looked up Vanos rattle, but does this only affect pre-facelift models?
2008 E85, approx 32,000miles/51,000km, oil and filter changed every year.
Any ideas what this might be? I saw DLV mention an aux belt noise on another thread but couldn't hear anything when I listened to the video, so none the wiser if this might be something to look at.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- R60BBA
When you put it in for service do you get a shims report?
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- Buckz
dmf rattle? push you clutch in and see if the noise goes away.
Shims?
N52 is a fit and forget engine as far as BMW servicing is concerned. Servicing equals visual checks, changing fluids, filters and spark plugs only. I think Ms (S54) are the only engines with routine lifter re-shimming at services?
Chris
Chris
08 Z4 3.0si Sport Coupe in Montego Blue
- R60BBA
Shims should be checked on an Inspection 2.
If they haven’t been checked get them done at your next service.
- hopz121
Not on a N52 mate
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- R60BBA
http://www.engineprofessional.com/TB/TB110915-1.pdf
- R60BBA
- hopz121
That doesn't mention shims only changing the valve lifters which is a fairly common issue on the N52 engine as we all know, this isn't a servicing item.
- R60BBA
BMW Park Lane include valve clearence as apart of their Inspection 2.
- hopz121
Not on an N52 they don't
- ph001
Dare I ask if it sounds similar to this?..... https://www.youtube.com/watch?v=cgtHUhG ... e=youtu.be
Here are a full 9 pages to read on it! Still don't think the mystery has been solved as far as I know
https://z4-forum.com/forum/viewtopic.php?f=3&t=100400
- Marlon
I hope not for the OP's sake - absolute nightmare that threadph001 wrote: ↑Thu Feb 01, 2018 4:39 pmDare I ask if it sounds similar to this?..... https://www.youtube.com/watch?v=cgtHUhG ... e=youtu.be
Gone: 3.0si 2008 E85
911 997 Carrera S
- enzed4
No clutch, it's not a real man's car sorry
No, that sounds like a definite 'clatter' - mine's more of a fast vibration, almost like something has heated, expanded, and is touching something it doesn't when cold (which made me think of the heat shield).ph001 wrote: ↑Thu Feb 01, 2018 4:39 pmDare I ask if it sounds similar to this?..... https://www.youtube.com/watch?v=cgtHUhG ... e=youtu.be
Thanks for the suggestions so far, looks like I might have to upload a clip to see if it helps pinpoint it.
Gone: 2010 35i DCT
