Roof button - no lights?
Jez_m
Post by Jez_m » Thu Jan 25, 2018 5:13 pm
Haven't used the roof for a while.. today, went to put it down and pressed the button.. nothing! No light, no movement, nothing!
Have had a replacement roof motor relocated to the boot so pretty sure thats not the issue. Have'nt had a look at fuses yet.. but is this something that commonly blows?
Mike6
Post by Mike6 » Thu Jan 25, 2018 5:51 pm
First thing is to check is that the parcel shelf in the boot is correctly seated. If its levers have put put in the up position to allow more space in the boot then your symptoms will be what you get. Hopefully a two minute fix.
Scooba_Steve
Post by Scooba_Steve » Thu Jan 25, 2018 6:43 pm
Mike6 wrote: Thu Jan 25, 2018 5:51 pmFirst thing is to check is that the parcel shelf in the boot is correctly seated. If its levers have put put in the up position to allow more space in the boot then your symptoms will be what you get. Hopefully a two minute fix.
The shelf up/switch failed/switch disconnected gives an amber light, rather than no light.
Mike6
Post by Mike6 » Thu Jan 25, 2018 6:53 pm
Well done Steve, I stand corrected. Could it be that a connecter has worked loose on the motor.
Ducklakeview
Post by Ducklakeview » Thu Jan 25, 2018 7:07 pm
As above, the shelf being up would illuminate the light on the switch. However, I have had a case where the shelf switch wiring was faulty and no lights illuminated.
You need to check that the roof module is getting power and communicating. Easiest way to do this is to pull fuse no 12 and check it. Then if the fuse is ok, turn the ignition to position 2, wait a couple of seconds and then put the fuse back in whilst watching the leds on the roof button switch. If the module is powering up and coming online to the canbus network, the red led will come on for half a second or so. If that's ok, then try it again as sometimes the system loses track of the position of the roof and latching motor in relation to each other in which case the roof module shuts down as a failsafe.
If that didn't work, but you did get the momentary led when inserting the fuse, I would then pull and check fuse no 31 which supplies the latching motor.
After checking the switch and fuse as above, further investigation really needs a diagnostic check as a starting point otherwise you end up stabbing in the dark.
Mike
Ducklakeview
Post by Ducklakeview » Thu Jan 25, 2018 7:09 pm
Mike6 wrote: Thu Jan 25, 2018 6:53 pmWell done Steve, I stand corrected. Could it be that a connecter has worked loose on the motor.
No, in this case you would get the red light as the windows dropped and the roof unlatched, but then no actual movement.
Mike
G600
Post by G600 » Thu Jan 25, 2018 10:29 pm
I had the same problem, eventually I found a wire in the roof running to the latch motor had broken.
E85 3.0
Ducklakeview
Post by Ducklakeview » Thu Jan 25, 2018 11:04 pm
G600 wrote: Thu Jan 25, 2018 10:29 pmI had the same problem, eventually I found a wire in the roof running to the latch motor had broken.
Which a proper diagnostic would find quickly :)
Mike
Jez_m
Post by Jez_m » Thu Jan 25, 2018 11:07 pm
Thanks for the suggestions. :)
Will start with the fuse tmw.. hopefully a quick fix!
G600
Post by G600 » Fri Jan 26, 2018 9:21 pm
Ducklakeview wrote: Thu Jan 25, 2018 11:04 pm
Mike
Correct, carly pointed me in the right direction
E85 3.0
Coffee331
Post by Coffee331 » Fri Jan 26, 2018 11:20 pm
I had a similar issue...turned out to be the roof control module.
Jez_m
Post by Jez_m » Sun Jan 28, 2018 3:22 pm
Am now getting flashing red light. No roof action.
Jez_m
Post by Jez_m » Sun Jan 28, 2018 3:23 pm
Front motor only working off the key fob presses.
Won’t latch at the front now! Arghhh
Jez_m
Post by Jez_m » Sun Jan 28, 2018 3:24 pm
Jez_m
Post by Jez_m » Sun Jan 28, 2018 4:47 pm
So i've got flashing roof top red light, the buttons do nothing at all. Roof is unlatched at the front, when i press the roof close on the key fob (unlock unlock lock) it activated the front motor which locks it in then releases it again!! as per video above link.
Microswitch seems fine, metal clip is engaging when shelf goes down.
So i am stuck with a car that has the roof unlatched and a week of commuting ahead of me! great.
