Roof button - no lights?
- markplant
You appear to have a gaptech type device fitted, so I'd remove that an see if cures the problems, it may be a bad connection or a faulty unit
found the torx bolt that latches the roof, so have manually tightned that down, so at least i have a fully closed roof!
CHecked the gaptech connections, all good.
- markplant
Are they soldered connections or the crimps that shear into the cable
they are crimped on connections. Had a good look / feel of all of them and they seem fine. Lost the light now, but could be worth re-doing them.. although as they haven't been disturbed i would be suprised if they could just suddenly lose connection.
Had my roof motor re-located to the boot (refurbed replacement) about 2 yrs ago. Hoping it's not that already!
Just have red light flashing, no window drop down, nothing! hmmmm
Changed over micro switch to brand new replacement.. disconnected battery to reset everything... and now, no roof lights, no action... nothing!!! Hmmmm
Any ideas anyone?
Any ideas anyone?
- Smartbear
I would remove the roof module & go from there.
e85 3.0si sold
The one behind the passenger seat?
Haven’t checked for any fault codes yet.. maybe I’ll see if anything comes up
- Crazy Harry
Before you spend any more money I would get the codes read - even if you have to pay out it could well save you money in the long run. For what its worth I disconnect the gaptech. Mechanical connections have failed for a lot of other forum members and I think a couple of members have had the gaptech units themselves fail.
I’ll get my code reader out when I’m home next, def sounds like it’s worth a check.
Gaptech.. maybe it is.. sudden failure though? The only thing still working is the remote roof lowering, after pressing the unlock three times the front motor whirs open then immediately shut again. So the gaptech is getting signal and trying to start the process... which makes me think the ecu is then not doing its bit..
- Bing
I’ve got a gaptech, my roof throws a wobbly very occasionally, refusing to move on the cabin button press, needs held when it shouldn’t or flashes a red light at me. I reckon it’s a dodgy crimp connection in mine. You should definitely remove it and see if the roof works without it. And when you put it back get brave and use bullet connectors, the are much more reliable.
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- Smartbear
Hi, not that one I meant the gaptec unit under the ashtray, as mentioned earlier the scotch clips supplied are useless and prone to open circuits
e85 3.0si sold
Gaptech removal is first on the list for next Sat followed by code reading. Have also ordered a replacment roof ECU in case it's that.
Look forward to marking this topic as solved!!
- MACK
+1 on the intermittent wobble. Took mine out in the end for nine months and not one wobble. Put the Gaptech back on and a month or so down down the line the roof played up. Mine was soldered in both times, once by the previous owner and the second time by me, so I think it's the actual unit rather than the connections.Bing wrote: ↑Mon Feb 05, 2018 8:36 pmI’ve got a gaptech, my roof throws a wobbly very occasionally, refusing to move on the cabin button press, needs held when it shouldn’t or flashes a red light at me. I reckon it’s a dodgy crimp connection in mine. You should definitely remove it and see if the roof works without it. And when you put it back get brave and use bullet connectors, the are much more reliable.
Silver 05 3.0i SE
White E89 20i M Sport
So, new roof ecu module fitted and gap-tech removes.. no joy. Top red light is just flashing away.. no action,no windows down.. nothing! Hmmmm
Have you checked the emergency handle (red loop) in the boot hasn't been inadvertently knocked?
Also, does the motor reservoir have sufficient oil it it? Try opening and closing the roof manually a few times..
