Fault code 93e7
Fault code 93e7
Anyone had a experience with fault code 93e7 door airbag type incorrect sensor
- mac27040
Fault code 93e7
93E7 Airbag sensor, door, front right: incorrect measuring range
also see this https://z4-forum.com/forum/viewtopic.php?t=96416
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
Fault code 93e7
I wonder if I purchased the wrong battery as it’s a little smaller then the other one I had ?
- mac27040
Fault code 93e7
what battery did you get?
Fault code 93e7
It was lion
https://www.eurocarparts.com/ecp/c/BMW_ ... 4a9&000020
The difference the other one was 20 mm bigger in length
Fault code 93e7
62 amp and 248mm long I wonder if it’s meant to be 70amp and 278mm long as I think that’s what came out
Looks like an error in my part
- Ducklakeview
Fault code 93e7
Having that battery wouldn't cause that error code.
Mike
Mike
Fault code 93e7
If it’s meant to be 70 amp and I have stuck a 62 amp in would it not ?
Fault code 93e7
A 12 v battery, is a 12v battery. The current rating (amps) is just how much 'oomph' it has got. As long as the battery isn't faulty or flat it shouldn't cause any issues at all.
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:Brand new Pierburg water pump fitted at 101k after failure (should have done it at 100k)
