Hi,
I'm hoping someones had a similar problem and know's the fix. My Sat Nav module has gone dead. It won't fire up and the tilt and open close refuse to work.
Is there a fuse for it? Or am I going to have to "reset" the car and hope it fires up into life?
Cheers for any info
T1b
SAT NAV on the fritz
- T1berious
Current
718 Cayman GTS 4.0, Kia EV6 GT line S
F87 M2C ,F82 440i, E85 Z4MR, E92 330i All Gone!
- srhutch
- Moderator
You might want to check the connection to the screen.
More than likely though is a problem with the stepper motor, which is why the screen won’t open. Without this the screen won’t work even if manually opened.
- T1berious
Sorry, I should have made a better explanation.
The screen is open but won't display anything.
So it's in the up position but is blank and doesn't respond to the open close button or tilt.
Any ideas?
Any ideas?
Current
If your battery is a fair few years old chuck a new one on and see if it makes any difference before you chuck money at the actual satnav/screen.
- srhutch
- Moderator
What happens when you turn the ignition off?
If nothing I would check the connection
- T1berious
Nothing happens on turning the ignition off, I was looking at the fuse sheet and F49 is for satnav /tv hopefully it's just the fuse. I'll let you know later tonight
Current
- T1berious
Joy, finally got around to checking fuse 49 and it's blown. the bad news is it keeps blowing every time I replace it.
I'll try "resetting" the car at the weekend and see if I can replace the fuse while the battery is disconnected.
Current
