3.0si Changing gear
3.0si Changing gear
hi all.
so i test drive a high mileage coupe today. i found it very fun to drive but the first 3 gears seemed to be overly stiff - i had to really coax them in. is this normal for a z4? i own an astra 2.0T estate and that gearbox is a lot easy to change.
i suppose i should test a few more examples to make up my own mind but thought i would share
- Buckz
3.0si Changing gear
yeah, 1st and 2nd are difficult to get in/take time to get used to some say changing gearbox oil helps but I personally got used to it and it's fine now.
it's a stiff/sporty gear change for sure.
- Ethicsgradient
3.0si Changing gear
Its a positive change , it likes you to recognise nuteral . The 350z is very much the same ..you change 1st N 2nd N 3rd .. Rather than just slamming it through like on a honda S2000 or similar .
- Yorkie Z
3.0si Changing gear
I'd say it's probably fine, rather than stiff its quality your experiencing
A Dirty M///
3.0si Changing gear
thanks guys. I had fun test driving it - so much so i forgot to press the sport button. what does that do exactly? is it like the millenium falcons light speed button?
- srhutch
- Moderator
3.0si Changing gear
Stiffens the steering and increase throttle response on a N52 engined car.
Holds onto gear longer on autos also.
- Smartbear
3.0si Changing gear
Doesn’t give you any extra power, it just feels like it does due to changing the fly by wire throttle map
e85 3.0si sold
3.0si Changing gear
Turns the car from a pussy cat into a beastMiage wrote: ↑Sat Jan 06, 2018 6:11 pmthanks guys. I had fun test driving it - so much so i forgot to press the sport button. what does that do exactly? is it like the millenium falcons light speed button?
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Ducklakeview
3.0si Changing gear
Removing the clutch delay valve improves the changes no end..
Mike
Mike
3.0si Changing gear
Thanks guys my astra has the same feature then
3.0si Changing gear
A gearbox oil change also helps quite a bit. I'd say they're a notchy box, when I get around to getting a clutch and DMF swap will change the mounts too as that may also help some more.
- Mr Tidy
3.0si Changing gear
Yes, they don't have the slickest of gear-changes!
Mine has no CDV, and putting a ZHP gear-knob on when I had the gearbox oil changed made a huge difference.
Confession time - I've never used the Sport button.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Rusky
3.0si Changing gear
Mr T, is that never as in never ever
3.0l Silver SMG, whippy and ginge fringe/ Sound gen mod/ Media bridge fitted (bluetooth and audio streaming) / Clear third break light/ Hard Top/ Eibachs springs and DLV back box/ Roof motor in the boot/ plus lots more.
- Ethicsgradient
3.0si Changing gear
What annoys me about the sport button is it does not stay on , my jag when you put it in sport it stayed there , stop , switch off engine , go to work , come back , start up , still in sport .
- Silverzedtom
3.0si Changing gear
That would be handy. I press the button with the ignition on before I start, don’t even think about it any more. 1st world problems eh?Ethicsgradient wrote: ↑Sun Jan 07, 2018 12:56 pmWhat annoys me about the sport button is it does not stay on , my jag when you put it in sport it stayed there , stop , switch off engine , go to work , come back , start up , still in sport .
E85 2.5si
F55 Cooper S
F55 Cooper S
