Aircon pump makes the zed sound like an old taxi :/
- Chris_D
As per topic subject; took me a while to diagnose, usually when standing at traffic lights with the engine running but switching the aircon off gets rid of the old mkii diesel Sierra effect!
Anyone else experienced similar? Clank clank.
- Ducklakeview
Play in the front clutch bearing, OR is it rapidly clicking on and off? If so, could need the endfloat for the electromagnet adjusting, which is a pain, however if this is what's happening, I have a quick, cheap and permanent fix Chris - Let me know..
Mike
Mike
- Chris_D
Cheers mike, that's an interesting/kind offer. It's not really a concern atm, just a minor irritation for which I'm curios as to whether others are experiencing.Ducklakeview wrote: ↑Tue Dec 26, 2017 11:22 pm Play in the front clutch bearing, OR is it rapidly clicking on and off? If so, could need the endfloat for the electromagnet adjusting, which is a pain, however if this is what's happening, I have a quick, cheap and permanent fix Chris - Let me know..
Mike
You sound like youve had experience in this department?
You reckon the compressors on the way out?
- Ducklakeview
Prob just excessive end float making the magnet is at the limit of it's operational distance. It's sometimes caused when the little rubber buffers disintegrate, causing the increase in distance.
Mike
Mike
- Chris_D
Aiight. Easy fix/adjustment? Leave it alone til it fails?Ducklakeview wrote: ↑Wed Dec 27, 2017 12:04 am Prob just excessive end float making the magnet is at the limit of it's operational distance. It's sometimes caused when the little rubber buffers disintegrate, causing the increase in distance.
Mike
- Ducklakeview
5 mins, just bend the lugs where the rubbers sit in towards the compressor by a couple of mm.
Mike
Mike
- Chris_D
Top. Thx. I'll av a butchers....Ducklakeview wrote: ↑Wed Dec 27, 2017 12:16 am 5 mins, just bend the lugs where the rubbers sit in towards the compressor by a couple of mm.
Mike
- MT94
Hi did this solve your problem as I have started to have this problem recently and is a worrying noise at first until you realise what’s causing it.Chris_D wrote: ↑Wed Dec 27, 2017 12:24 amTop. Thx. I'll av a butchers....Ducklakeview wrote: ↑Wed Dec 27, 2017 12:16 am 5 mins, just bend the lugs where the rubbers sit in towards the compressor by a couple of mm.
Mike
Matt.
2004 E85 Z4 2.2i Titan Silver
- Chris_D
I haven't actually addressed it yet.MT94 wrote: ↑Fri Feb 02, 2018 10:23 pmHi did this solve your problem as I have started to have this problem recently and is a worrying noise at first until you realise what’s causing it.Chris_D wrote: ↑Wed Dec 27, 2017 12:24 amTop. Thx. I'll av a butchers....Ducklakeview wrote: ↑Wed Dec 27, 2017 12:16 am 5 mins, just bend the lugs where the rubbers sit in towards the compressor by a couple of mm.
Mike
Matt.
It's not worrying me enough to start tinkering around outside in the cold yet....
