HELP Smoking
HELP Smoking
Well collecting the gasket set tomorrow, wont get it done this weekend though sadly, pleased its happened now if thats all it is and not half way round France in June.
DaveZ4richardson
3.0i 2003 E85 auto cruise control, smart top module.
- skelters
HELP Smoking
Same Gasket cheaper here... https://www.carparts4less.co.uk/search/368110470
Seemingly the same company run Eurocarparts and Carparts4less.
2007 Z4 3.0si Sport. Silver Grey Metallic, Brembo Brakes, HEL Braided Brake Hoses, Machine Monkey Exhaust Tips, Stubby, Piano Black trim, Black Leather, Bilstein B12-Pro-Kit, Michelin Pilot Sport 4 on MV2's. Roof Motor in the Boot!
HELP Smoking
Only trouble is i dont have a carparts4less near me.skelters wrote: ↑Mon Jan 01, 2018 10:31 pmSame Gasket cheaper here... https://www.carparts4less.co.uk/search/368110470
DaveZ4richardson
- skelters
HELP Smoking
Neither do I and still get most things from them for our cars. They deliver to your door via courier. It's an idea that'll never catch on!DaveZ4richardson wrote: ↑Tue Jan 02, 2018 7:24 pmOnly trouble is i dont have a carparts4less near me.skelters wrote: ↑Mon Jan 01, 2018 10:31 pmSame Gasket cheaper here... https://www.carparts4less.co.uk/search/368110470
Although if you need the part quick then it's only about £15 more from Eurocarparts.
HELP Smoking
skelters wrote: ↑Wed Jan 03, 2018 12:29 amNeither do I and still get most things from them for our cars. They deliver to your door via courier. It's an idea that'll never catch on!DaveZ4richardson wrote: ↑Tue Jan 02, 2018 7:24 pmOnly trouble is i dont have a carparts4less near me.skelters wrote: ↑Mon Jan 01, 2018 10:31 pmSame Gasket cheaper here... https://www.carparts4less.co.uk/search/368110470
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
HELP Smoking
Any tips how to get the cover off. The gasket looks like it has welded ot the cover!!!
DaveZ4richardson
- Chris_D
HELP Smoking
prize it off...carefully. once all the bolts are out of course.DaveZ4richardson wrote: ↑Sat Jan 13, 2018 1:21 pmAny tips how to get the cover off. The gasket looks like it has welded ot the cover!!!
You will probably hear and experience a cracking noise. That's just the gasket separating away from the mating surfaces.
I was filled with trepidation when i removed mine and when i heard a cracking noise i thought i'd buggered the cover.
Turns out it was just the solidified gasket.
Make sure that if the gasket does indeed shatter/break apart on removal that you recover ALL the broken bits if any escapes into the engine compartment otherwise the risk is that they wil be consumed within the engine internals.
I had to spend about an hour digging around looking for the 'last piece of the jigsaw' when i di mine. grrr
also...take pics...this thread is boring without them....
HELP Smoking
Its off. Changing plugs too. Bit if porcelain on plug broken off
DaveZ4richardson
HELP Smoking
9
Nightmare!!! Any tips how i get the broken bits out?DaveZ4richardson
- Chris_D
HELP Smoking
Blimey! It never rains when it pours!
That would give me cause for MUCH concern if bits have dropped into the chamber.
Boroscope and a strong shop vac i'd suggest....
Ceramic bits will def be more catastrophic than plastic bits blasting around ur engine internals...
HELP Smoking
The plug is still in the chamber. Just need to vacuum them out today then put it all back together. Should be fine hopefully.
DaveZ4richardson
- Silverzedtom
HELP Smoking
Go and hire an inspection camera from a tool shop and be sure. This could be catastrophic so worth checking properly.DaveZ4richardson wrote: ↑Sun Jan 14, 2018 10:17 amThe plug is still in the chamber. Just need to vacuum them out today then put it all back together. Should be fine hopefully.
E85 2.5si
F55 Cooper S
F55 Cooper S
HELP Smoking
Thanks for all the advice everyone, without your knowledge that job would of probably cost a few hundred quid.
DaveZ4richardson
HELP Smoking
Well, every picture tells a story. Oil leak on the rocker cover gasket, new gasket purchased along with plugs, stripped down slowly so i knew exactly where everything went, had a few traumas along the way. Mostly the porcelain on the plugs chipping off whilst being removed. Managed to retrieve all the broken bits. Put the car back together, fired up instantly, excess oil burnt off. This is the first time I have completed any mechanical work on a car so feeling rather proud of myself this afternoon. Cheers everyone.
DaveZ4richardson
- Silverzedtom
HELP Smoking
Nothing better than fixing something yourself knowing you saved some cash along the way
E85 2.5si
F55 Cooper S
F55 Cooper S
