Really weird problem!
kowsmou
Post by kowsmou » Wed Dec 13, 2017 8:12 pm
Ok so I have a 57 plate Z4 2.0 with 40k on the clock. I've been getting intermittent P0420 error codes last few weeks which is related to catalytic efficiency. When I say intermittent I mean I could go 300 miles and it won't come on! I took it to a BMW specialist who couldn't definitely narrow down what was causing it but he's going to change the pre-cat O2 sensor next week as it's covered by the warranty I have so it's not costing me anything. I have tried using Cataclean a few times which doesn't seem to have cured it.
Here's the weird thing, every single time the code is triggered and the dash warning lights up, I'm low on fuel, like on the first notch. From what I know, this has to be a coincidence, but it's not. I tested it a couple of times and sure enough as soon as the fuel runs low the check engine light comes on.
Any ideas what could be causing this ??
kowsmou
Post by kowsmou » Wed Dec 13, 2017 8:21 pm
I should add, the car runs absolutely fine even when the light comes on and low on fuel.
DPG
Post by DPG » Wed Dec 13, 2017 8:32 pm
Cracked manifold maybe
Audi RSQ3. The family wagon
kowsmou
Post by kowsmou » Wed Dec 13, 2017 8:42 pm
Light only comes on when fuel is low though... The BMW guy said he couldn't see any cracks in the cat or manifold.
srhutch
Moderator
Moderator
Post by srhutch » Wed Dec 13, 2017 9:21 pm
Real trait of these 2.0i zed s :cry:
kowsmou
Post by kowsmou » Wed Dec 13, 2017 9:57 pm
How do you mean sorry? I've not had one long!
andyfanshawe
Post by andyfanshawe » Wed Dec 13, 2017 10:17 pm
Hi srhutch. Can you expand on this?
andyfanshawe
Post by andyfanshawe » Wed Dec 13, 2017 10:23 pm
Hi kowsmou.
If this is as predictable as you say, plug in a good scan tool, pull up all 4 O2 sensors, and short term and long term fuel trim and record exactly what changes when the low fuel light comes on.
It may be the case that nothing does but something is causing the post CAT O2 sensors to not like what it sees. Live data willl pinpoint this without fail.
Also, you say he's going to change the pre cat sensor. Which one? Which bank? There are 4 sensors on this engine, even though it is the 2.0.
Which bank is the Po420 coming up on? I'm assuming its bank 1, since bank 2 is sometimes a Po430.
Andy.
andyfanshawe
Post by andyfanshawe » Wed Dec 13, 2017 10:27 pm
Oh, the reason the money light comes on when the low fuel does? The ECU may have a strategy that looks at various sensors at specific times. It may be programmed to look at the fuel level at the same time as it calculates the CAT efficiency from the data. Which could explain why they come on together.
Can't be certain but it's possible. Only the engineers who designed the system will know.
But for us, it doesn't matter. Concentrate on the Po420 and the reason its coming on first. Don't get bogged down by possible coincidences or not.
Andy.
Marlon
Moderator
Moderator
Post by Marlon » Wed Dec 13, 2017 10:28 pm
I will second this - I owned a 2.0 Zed for 6 months and in the last 2 months of ownership I had pretty much the same issue as you. After 2 or 3 hundred miles the engine warning light would come on - I'd clear it with a very basic OBD (can't remember the exact code but I know they weren't helpful in narrowing down the exact fault), and then after another roughly 2 or 3 hundred miles it would come on again. It didn't effect the driving experience and I never got to the bottom of it as I traded it in.
3.0si 2008 | Remap | M Sports Seats | Cruise Control
M wheel | 224 alloys | DLV box | CDV del | B06 knob
ph001
Post by ph001 » Thu Dec 14, 2017 10:40 am
Strange they are going for the pre-cat sensors when the fault is catalytic efficiency. It's the post-cat o2 sensors that determine the cat efficiency. The pre-cat sensors are used in closed loop mixture adjustment at part throttle opening (steady state cruising).
2004 E46 M3 coupe manual.
Ducklakeview
Post by Ducklakeview » Thu Dec 14, 2017 10:46 am
This..
Unless the ecu is comparing pre and post readings in order to determine efficiency?
Mike
ph001
Post by ph001 » Thu Dec 14, 2017 2:05 pm
Even the basic code readers like Carly can display lambda voltage - the pre-cat one should be oscillating between approx 0.8V and 0.2V every second or so. The post cat one should be relatively stable. If the post-cat one is oscillating much like the pre-cat one then it means that your cat is not doing it's job. If the voltage on the post-cat one is stable but at the wrong voltage (should be about 0.1 or 0.2V) then it's more likely a duff sensor.
coupedan
Post by coupedan » Thu Dec 14, 2017 2:41 pm
Could be way off here but fuel pump?
Maybe slightly dropping fuel pressure causing a "Cough" then throwing a lambda code because the values have drastically change from pre>post cat?
224M | Black Grills | Maxton Splitter | Aux | Michelin PS4 | Polybushed | Bilstein B12 Pro | E46 M3CSL Geo | 100K Mile Club :thumbsup:
Smartbear
Post by Smartbear » Thu Dec 14, 2017 2:54 pm
I think that would throw up a lean mixture code :?
e89 Sdrive2.0 18i, which has turned into a 20i :D
e89 Sdrive3.0i this ones busted, pass me another...
e85 3.0si, i sold my trouble free car...
