3.0si cooling issues
Wajakel
Post by Wajakel » Mon Nov 13, 2017 4:26 pm
Hi all, looking for some advice on an E86 3.0si with a weird cooling problem.
Recently the interior heater will not blow any warm air. If you keep driving it the temperature gauge starts to rise and fall quickly (between middle and red). Stopping and starting the engine sometimes fixes it.
Its been into my local garage twice. Most recently they said it had air in the cooling system and a flush fixed it. I went to pick it up just now and the following happened:
- Drove 10 mins home, temperature gauge went to middle, no heat at all from heater
- Stopped the car at home, restarted a couple of times, still no warm air
- Drove 10 mins back to the garage, the temperature gauge started to rise and fall, eventually resting near red, still no warm air
- Switched the car off, left it 10 mins whilst I spoke to the garage
- Switched the car on, temperature gauge was in the middle, interior heater was nice and warm, drove 10 mins home with no issues
My garage seems to think its the head letting air into the system and has suggested I speak to a BMW specialist. Any thoughts?
Cheers.
Online
MACK
Post by MACK » Mon Nov 13, 2017 4:46 pm
Sounds like the water pump fault that very common on that engine. I don't have direct experience if that fault on that engine myself but plenty do on here. Hopefully someone can confirm it.
05 3.0i SE in Titanium.
Mods inc - Facelift Xenons, M Sport Wheel & Leather Elec/Heated Seats, 15 & 20mm Spacers & M Tyre Sizes. 3M Carbon Fibre Trim, 4 Spot Clear Rear Lights, Gaptech+, Cruise, MM Tips, ZHP, Stubby.
Marlon
Moderator
Moderator
Post by Marlon » Mon Nov 13, 2017 4:54 pm
As Mack says the Electric Water Pumps on the si are prone to fail - but usually they fail abruptly and without warning and your temp gauge climbs into the red and stays there until the pump is replaced.
3.0si 2008 | Remap | M seats | M wheel
Cruise | Style 32 alloys | DLV back box
Wajakel
Post by Wajakel » Mon Nov 13, 2017 4:58 pm
Thanks both - yeah my initial thought was water pump but I assumed if the pump failed it would overheat really quickly? Whereas mine is sometimes fine and letting the car rest for a bit and restarting often fixes it.
Online
Buckz
Post by Buckz » Mon Nov 13, 2017 5:20 pm
some have reported them failing in a weird way, rather than a full blown fail they simply seem to fail to kick in on startup and work fine the next time..
Smartbear
Post by Smartbear » Mon Nov 13, 2017 6:32 pm
Hi, how old is your car & how many miles has it covered?
e89 Sdrive2.0 18i which has apparently turned into a 20i :D
e89 Sdrive3.0i this ones busted, pass me another
e85 3.0si-sold my trouble free car...
Online
ph001
Post by ph001 » Mon Nov 13, 2017 7:02 pm
Water pump for sure. Don’t drive it until you have changed it. If you cook the engine you are looking at big repair bills.
2004 E46 M3 coupe manual.
Silverzedtom
Post by Silverzedtom » Mon Nov 13, 2017 7:06 pm
Sounds like the pump to me too. Have you tried going through the bleed procedure again? It is known to take a couple of goes to get rid of all the air
Z4 2.5Si sport titan silver with Syrah blue interior | CSL reps | ZHP gear knob | Eibach pro kit springs | CDV delete | Wiechers racingline strut brace | Ram air scoop | Matt grill | Blue Calipers | de-badged | muffler delete | K&N | Stubby
Wajakel
Post by Wajakel » Mon Nov 13, 2017 7:27 pm
2006 & 118k
Wajakel
Post by Wajakel » Mon Nov 13, 2017 7:50 pm
Just followed the guide for the bleed procedure and the water pump didn't seem to startup. I've never done it before so I'll give it another go when its not dark and raining. Could indicate the pump has failed though?
Silverzedtom
Post by Silverzedtom » Mon Nov 13, 2017 8:01 pm
If the pump isn’t starting whilst going through the bleed procedure then it sounds like more evidence for a knackered pump. Don’t forget it’s a good idea to connect the car to a power source as the procedure is a big drain on the battery.
Not sure what dealers / indies are charging for the labour but if you decide to DIY then here’s a link:
viewtopic.php?t=18804
If nobody has found an easier way then it looks like you’ll need to know your way around a set of spanner’s after skimming through those steps.
Hope you get it sorted soon
Online
MACK
Post by MACK » Mon Nov 13, 2017 8:16 pm
2006 & 118k
At that mileage this may even be a second pump failing. The reports on here seem to be 60-80k as the usual range. I guess your car could still be on the original one though. As buckz said earlier there are few reports on here of them failing intermittently before packing up completely which sounds like it might be the case here.
Online
ph001
Post by ph001 » Mon Nov 13, 2017 9:02 pm
That guide is not for an N52. Completely different. It’s an easy 1hr diy. £250 for the pump and I’d be changing the stat also at that mileage.
coupedan
Post by coupedan » Fri Nov 17, 2017 3:30 pm
Sounds like pump - Mine failed at 118-119k miles.
That was my car's first one too.
224M | Black Grills | Maxton Splitter | Aux | Michelin PS4 | Polybushed | Bilstein B12 Pro | E46 M3CSL Geo | 100K Mile Club :thumbsup:
85genius
Post by 85genius » Fri Nov 17, 2017 5:00 pm
Mine failed gradually over the course of a couple of months so they don't always go the same way,
If you have an OBD reader you can do a fault code scan on the free version of the carly app to confirm.
Order the pump from Germany much cheaper than the UK suppliers even with shipping accounted for.
I didn't bother replacing the stat as the mechanic said its a piece of piss to get in and change if it ever fails so not worth replacing unless it throws up a fault
Current- Ruby Black 3.0 SI Roadster - Lots of toys
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
Who is online
Users browsing this forum: No registered users and 9 guests
