Occasional coolant light !
- earthdweller
I’ve had the coolant warning light cone on twice now .. but only on starting the car having not used it for a couple of weeks
If I turn the car off .. the turn it back on the light does not come back on
I’ve checked the levels etc and can’t see any problems
Any thoughts ?
Any thoughts ?
07 3.0si Sport Roadster Titanium Silver/Syrah Blue Individual Leather, CSL reps ZHP
- ph001
First thing - does the float all look OK and move freely when you remove the cap?
If you are 100% sure you are not losing coolant then you have to assume a sensor problem - this sits on the bottom of the expansion tank, you can see it clearly with the undertray off.
Personally I would add some coolant right up to the max level and see how you go. Any coolant loss is almost certainly a hairline crack in your expansion tank.
- Ducklakeview
Or, perished O rings where the expansion tank fits to the rad, this was my problem..
Mike
Mike
- earthdweller
Thanks guys I’ll have a good look and update
But I’m in lanzarote at the mo so it will be next week
- Ducklakeview
earthdweller wrote: ↑Wed Nov 01, 2017 7:04 pm Thanks guys I’ll have a good look and update
Typical Z owner, on hols and thinking about the car...
Mike
My coolant light just came on for the first time. Coolant was low, so I added. Will check it in a couple of days to see if I have a leak.
2007 3.0i
2007 3.0i
- earthdweller
As I say it only happens when the car has been left for over a week without being used
- earthdweller
Ducklakeview wrote: ↑Wed Nov 01, 2017 7:17 pmearthdweller wrote: ↑Wed Nov 01, 2017 7:04 pm Thanks guys I’ll have a good look and update
Mike
Yup ... Cold beer in hand sitting opposite the wife and thinking about the Zed and not the view
Andy
- silverzed
hi, I have the same problem, the coolant light comes on when the engine is cold, switch ignition off and on again , the light is off. going to check the coolant level and any signs of leaks this weekend
- ph001
It's normally pretty simple - if the coolant is low it's either a crack in the expansion tank or perished o-rings where the expansion tank fits to the rad. If coolant level is fine but you have a light on it's usually the sensor (fitted to bottom of expansion tank).
I know this is an old thread but thanks for the information. Now I need to by the sensor and replace it or get my mechanic to do it.ph001 wrote: ↑Thu Mar 22, 2018 3:35 pm It's normally pretty simple - if the coolant is low it's either a crack in the expansion tank or perished o-rings where the expansion tank fits to the rad. If coolant level is fine but you have a light on it's usually the sensor (fitted to bottom of expansion tank).
- Mr Tidy
Wow - top marks for some serious lurking! 1st post more than 7 years after joining.
Now you've broken the ice I'm sure an introduction and some photos on the Newbies section would be appreciated.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:Brand new Pierburg water pump fitted at 101k after failure (should have done it at 100k)
