Excuse me, I resemble that remark!! Somerset is a long way from Leicester but by all means contact me if you find yourself down in this corner Pete.
E85/E86 Steering Problems (Solved)
- wonkydonkey
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
- bladeowner
PeteWard wrote: ↑Fri Dec 14, 2018 1:09 pmJust a quick update... I've been to Sytner and their head technician said that they can't do the work, as "it's not a BMW approved repair", which is what I expected them to say. I'm considering have a go at it myself, I've ordered an 8mm flexible head ratchet spanner. I'm fairly handy, but haven't got any experience of working on cars. Do you think this is a good idea?! If I follow the instructions on here, what's the chances of me creating a disaster?!
It is now a BMW approved repair as it's in the TIS see further back on page 4 of this thread or here: viewtopic.php?f=3&t=100725&start=45
It's a simple procedure but access is awkward if you have a go yourself.
2004 Sapphire Black 2.5 SE Z4 SMG
- wonkydonkey
PeteWard you shouldn't really get in a mess with it. If you find you can access (and undo) the two bolts in question, you can have a fiddle. If you mark the adjustor ring and the housing it butts up to before you make any changes, you will be able to revert the steering back to its current setting. As I've had practice on a few now I can make the adjustment in about 15 minutes, but I know some have struggled. If you don't manage it, you're no worse off than you are now
Previous:
<My name is James>
<My name is James>
- wonkydonkey
PeteWard indeed. If worst comes to worst and you can't undo the two clamp bolts, all you have to do is refit the footwell trim panel (3 crosshead screws) you removed to gain access. I haven't used a torque wrench for this job, no.
Previous:
<My name is James>
<My name is James>
Onlinemarkplant
PetePeteWard wrote: ↑Sat Dec 08, 2018 2:01 pmYes, it's a long drive. Thank you for the offer, James.wonkydonkey wrote: ↑Sat Dec 08, 2018 1:59 pmExcuse me, I resemble that remark!! Somerset is a long way from Leicester but by all means contact me if you find yourself down in this corner Pete.
A few people you could ask the question to ,
James at Bmwman at heanor near the IKEA between notts an derby, a few on the forum are happy with his work.
Or Andy fanshawe, who is in chesterfield and runs a small shop had a restoration thread on here an is very thorough.
Thought my steering felt vauge so I tightened the ring up a little a while ago. No discernable effect so tried a little tighter today. Short test drive followed by tightening a little more and repeat. Then realised it was sticky steering after all. Backed it off to about 10 mm past where I started and it feels like a new car. So much more confidence at speed now.
So thanks to the OP. I'll be out later giving it a proper test drive.
E85 3.0 M54 Titanium Silver. 88k. Cotteswolds.
At 6'5" there was a bit of contortion required but very easy to adjust. Although I used an 8mm ratchet spanner as I couldn't see any way of getting a socket onto the clamp bolts.
Hi Jamie,
Just a question, does the issue you have on motorways feel like a badly balanced wheel?
