E85/E86 Steering Problems (Solved)
- wonkydonkey
Johnny B you must be the fella I replied to on YouTube but I didn't hear back. It costs nothing to adjust the eccentric ring and provided you mark its position before you turn it, it's entirely reversible. Torque wrench isn't really needed if you have an experienced feel for such things.
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
Yes that was me. Thanks for the reply. As I said I am going to try to adjust the ring. As you say if I mark the position there is nothing to loose. Do you think it will make the steering light again.
- wonkydonkey
I presume you're somewhere in South Wales. If so, I'm not a million miles away (near Burnham On Sea) if you decide you need help. I don't have an extensive description of your steering symptoms so can't really make a judgement yet, but by all means report back with your findings when you've had a go.
Previous:
<My name is James>
<My name is James>
I am in London. Yes went out in the car just now. Feels very heavy and sluggish perhaps because it is cold etc. Part of me thinks the steering rack and tie rods are a bit shot. The car is really good otherwise.
- Newbers
Can anyone tell me - would removing the fuse for the power steering and seeing if it has any impact on my hideous handling problems (as moaned about here viewtopic.php?f=3&t=117848&start=30) be a way to diagnose the problems discussed in this thread?
Coupe, KW coil overs, PSB limiters, Powerflex ARB bushes, 18" CSL reps, Aero skirts, ZHP leather knob, Whippy and proud. Probably needs a wash
I'm still having this issue after a 5mm adjustment last summer. What would be a good setting to move the worm gear to? 10-15mm?
- wonkydonkey
The real answer is to adjust it while checking steering feel with the road wheels off the ground until you dial out the stiction. There is no predetermined "correct" amount to adjust it by
Previous:
<My name is James>
<My name is James>
- yg54sg
Brilliant thread , I’m going to try this to fix my sticky steering next week, just to add I recently I refurbed my steering angle sensor which involves disconnecting the lower steering shaft in the engine bay , I changed the bolts on both steering universal joints (inverse Torx) to longer bolts with a nut on the end also using thread locker , the upper uj one totally stopped play on the steering which I thought was the rack. The rod has a groove in it so it cannot fall out while the bolt is in there but the bolt can come slightly loose and cause slight play as documented on forum years back , I think this is due to the fact that in the z4 eps Models the eps unit is in the cabin so this rod is under more stress than in say the mz4 where the rack is assisted itself with less stress on the shaft
54 3.0i SE, Sterling Grey, 6sp Manual, Dream Red Heated M Sports Seats, Pro Navigation, Carver DSP Sound, Xenon,
Mods: facelift rear bumper + lights LCM reprogram, LED DRL rings, Clear hockey sticks, clear side repeaters, powerflex bushes
- redtailed78
I tried and failed to do mine, bought a ratchet set from ToolStation that I thought would be ideal but I cant get it on the back one as the spring gets in the way.. The front one was so tight it felt like someone must have put it on with an air gun
Anyone recommend somewhere in Scotland that can sort it or would Zed Shed be the nearest? I also need to get the window regulator done af the same time.
2006 3.0lSi Sport
19" 313 alloys
Brembo Brake Upgrade
K&N Panel Filter
Back Box Delete
19" 313 alloys
K&N Panel Filter
Back Box Delete
- wonkydonkey
redtailed78 did you adjust the steering wheel so that it was pulled all the way out towards the driver and down as low as possible? This gives maximum clearance for accessing those bolts. (I THINK the wheel needs to be fully down rather than fully up, from memory)
Previous:
<My name is James>
<My name is James>
- redtailed78
wonkydonkey wrote: ↑Sat May 30, 2020 4:04 pm redtailed78 did you adjust the steering wheel so that it was pulled all the way out towards the driver and down as low as possible? This gives maximum clearance for accessing those bolts. (I THINK the wheel needs to be fully down rather than fully up, from memory)
Yeah I had the steering wheen at lowest point then extended as far as possible, my wifes dad has got other ones I might try and hopefully get it going
2006 3.0lSi Sport
19" 313 alloys
K&N Panel Filter
Back Box Delete
19" 313 alloys
K&N Panel Filter
Back Box Delete
- wonkydonkey
redtailed78 I've only ever done them with spanners. Trying to get sockets in there seemed too fiddly. Might be worth a go
Previous:
<My name is James>
<My name is James>
+1 for the spanners. I can get at mine using an 8mm ring spanner but I need to be on my back in the foot wellwonkydonkey wrote: ↑Sat May 30, 2020 6:50 pm redtailed78 I've only ever done them with spanners. Trying to get sockets in there seemed too fiddly. Might be worth a go
2003 Launch car : 3.0 litre E85 in Sterling grey
- Reamesy
Joycey, You sir are a legend!
Today I used an 8mm spanner with another on the end and adjusted the ring by 14mm anti-clockwise. It has transformed my car! It now drives like a BMW should. My steering was like having a ghost pulling left and right between 65-70 mph. Now its solid. Feels like my 4 series.
Only took 30 mins in total.
Thank you
Thank you
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Guess what i am getting my mechanic to do when he does my MOT
Hope this works, mine isn't bad but it certainly doesn't feel normal.
