E85/E86 Steering Problems (Solved)
Thanks - I'll adjust the ring and keep you posted!
- Jsomerville
Hey mate, I have had my Z4 for about a month and it seems like I have the exact same issue.wonkydonkey wrote: ↑Tue May 08, 2018 8:14 pm I'm based in Somerset and would be happy to help anyone nearby who isn't sure how to tackle this issue.
Any chance you could lend a hand? I am based in Somerset also!!
2004 3.0i // 19" Gunmetal CSL's // 3.0si Brakes// Bilstein B4's // ZHP // M-Stiched Steering Wheel // Sound Gen // Polybushed Control Arms // Xenons // Cruise // VANOS + DISA rebuild // M Pedals
Just adjusted my e86 tonight, was getting a slight steering wheel pulse at 60-70 varied depending on road surface, noticed it first on the drive home after picking it up a few weeks back. Put it down to the coil overs and 19” wheels.
Anyway after removing the coil overs, still happening, so initially tightened 10mm and no wobble but sticky steering, so backed up 5mm and it’s bob on.
Big thanks to all who post these free fixes, although think I need physio after spend 20 minutes upside down under the steering wheel.
I used 8mm ratchet spanner and a big ring spanner on the end for leverage
1994 Landcruiser VX 80 Series
2006 Z4 Coupe Sport
2006 Z4 Coupe Sport
- wonkydonkey
Absolutely. Will drop you a PM.Jsomerville wrote: ↑Mon Jul 01, 2019 9:20 amHey mate, I have had my Z4 for about a month and it seems like I have the exact same issue.wonkydonkey wrote: ↑Tue May 08, 2018 8:14 pm I'm based in Somerset and would be happy to help anyone nearby who isn't sure how to tackle this issue.
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
- wonkydonkey
How did you get on, Steve?
Previous:
<My name is James>
<My name is James>
It took a while, but I just did it on my 2005 Z4 CDN model. After removing the lower steering wheel cover and the footwell cover..ionofchios wrote: ↑Wed Feb 07, 2018 6:01 pm Just had a go at this, but can’t get enough leverage on the bolts with my hand up inside the dash. Mine’s and e86 and it has allen bolts, not torx. I’ve got an allen bit, then universal joint, short extension, then T piece (all 1/4 inch), but I can’t get enough leverage on it. There’s not enough room to get anything longer up in there either. I suppose I’ll have to take the whole steering assembly out if I can’t find a way.
Any advice?
Front: 6mm 1/4 inch bit in a 1/4 inch socket, attached to a swivel, then a 6 inch extension and then a 3 inch extension, then the ratchet drive. This was accessed above the knee airbag. Patience to get the hex bit in. then applying force to keep it in, and snap it off.
Back: 6mm 1/4 inch bit in a 1/4 inch socket, attached to a swivel, then a 3 inch extension, then the ratchet drive. This one is easier.
What fooled me was the eccentric ring is a separate unit sandwiched in between. Kept trying to turn the servo unit. duh. I set it at 10mm as per suggestions from other members. Will test tomorrow in the 32*C heat wave in Ottawa.
Best of luck to all you DIY North American owners.
i managed to get a short-ended Allen key on the nearest one, and the back one a managed to get with the same key but long-ways and at an angle (it has one of those ball-ends, so you don’t have to get it in dead straight), and was able to get some pliers in there to grip the short end and get leverage. I then replaced the back one with a bolt which I was able to get to with a normal spanner, with a bit ground off of one side to get some rotation room.
Sorry mis-post. See below
2004 3.0i SE in titanium silver with clear third brake and side lights. Black interior.
M-Sport suspension, 18” 107 mag ellipsoids, ZHP, xenons, cruise control and stubby
Sorry it’s taken so long to post a reply, Wonkydonky, but my zed’s been off the road for some time, so I’ve not been posting. Before I got a chance to look at the adjustment, I had a critical failure of the eps, which resulted in a total rebuild and refurbishment. After the refurb, my steering is as tight as a duck’s bum, but unfortunately, I’m faced with a four-figure bill which, after laying out for new tyres and a service is less than welcome.... There may well be a hard top for sale soon....wonkydonkey wrote: ↑Mon Apr 08, 2019 1:44 am Ala5dair let us know how you get on. Also, from a diagnostic standpoint, don't forget that this problem is affected by temperature. Running the air con on cold blowing hard at your feet for 5-10 mins or so can reduce the effect of sticky steering. Conversely, blowing hot for 5-10 mins can make it worse. Perhaps try these to see if they affect the stiction you experience. If so, the adjustment should be the solution.
- wonkydonkey
Ala5dair ouch, sorry to hear that The last member's car I adjusted the column on needed a huge adjustment. His column too had been removed, refurbished and then refitted. It was about as tight as I've felt a sticky steering column. It's spot on now though, so you're just a quick fiddle away from a happy day!
Previous:
<My name is James>
<My name is James>
Just a note to say how lucky I was to resolve a sticky steering issue.
I went to a members house who had offered to fix the problem- which he did.
It just shows how vital it is, to have access to this forum.viv thomas
Grateful thanks to wonky donkey
Sorry, but I obviously wasn’t clear in my previous posting. By “tight” I meant “perfect”. The steering is direct, with no tramlining, and seems unaffected by temperature and time. So now, with sorted steering and new Pirelli PZero (non-RFT’s) my car is a delight to drive....wonkydonkey wrote: ↑Wed Jul 10, 2019 9:23 pm Ala5dair ouch, sorry to hear that The last member's car I adjusted the column on needed a huge adjustment. His column too had been removed, refurbished and then refitted. It was about as tight as I've felt a sticky steering column. It's spot on now though, so you're just a quick fiddle away from a happy day!
- wonkydonkey
The internet certainly has its uses! You're entirely welcome. I'm glad you can enjoy the car again now
Previous:
<My name is James>
<My name is James>
- wonkydonkey
I seeeee. Happy days!Ala5dair wrote: ↑Thu Jul 11, 2019 9:41 pmSorry, but I obviously wasn’t clear in my previous posting. By “tight” I meant “perfect”. The steering is direct, with no tramlining, and seems unaffected by temperature and time. So now, with sorted steering and new Pirelli PZero (non-RFT’s) my car is a delight to drive....wonkydonkey wrote: ↑Wed Jul 10, 2019 9:23 pm Ala5dair ouch, sorry to hear that The last member's car I adjusted the column on needed a huge adjustment. His column too had been removed, refurbished and then refitted. It was about as tight as I've felt a sticky steering column. It's spot on now though, so you're just a quick fiddle away from a happy day!
Previous:
<My name is James>
<My name is James>
Mr Donkey I was wondering if I too could make use of your fix? I am up near Oxford but happy to travel down if you think you can help! Thankswonkydonkey wrote: ↑Fri Jul 12, 2019 6:11 am The internet certainly has its uses! You're entirely welcome. I'm glad you can enjoy the car again now
