E85/E86 Steering Problems (Solved)
- enzed4
Anyone know if this fix might be applicable to E89's? The symptoms are very similar to what I'm experiencing (go back to the original description of 'knocking' rather than light or heavy steering/stickiness). I've changed the 17" RFT's to 18" non-RFT, had wheel alignment done, and had garage check all the bushes etc (twice now). All that seems left is suspension (Bilsteins) or possibly the fix in this thread.
I get vibration in the steering wheel when going around roundabouts and clunking/knocking when driving slowly on smooth roads or coming to a stop/starting from a stop.
Happy to give this solution a try if the E89 has the same ring adjustment
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- Leesfarm07
Maxman that's a fab offer which I would love to take up thank you...let me know when would suit you best and I'll blow the cobwebs off the old girl
Current
2012 Mercedes SLK 250 AMG Sport auto in black
Westfield SE 1800 Zetec on twin 45's Aldon-Tuned pocket rocket in orange
Gone but not forgotten my lovely Zed 2.5
- enzed4
I removed the steering cowl and had a look around. Looks like there's no equivalent adjustment ring for the E89 (at least as far as I can tell).enzed4 wrote: ↑Sun Dec 30, 2018 3:25 am Anyone know if this fix might be applicable to E89's? The symptoms are very similar to what I'm experiencing (go back to the original description of 'knocking' rather than light or heavy steering/stickiness). I've changed the 17" RFT's to 18" non-RFT, had wheel alignment done, and had garage check all the bushes etc (twice now). All that seems left is suspension (Bilsteins) or possibly the fix in this thread.
Gone: 2010 35i DCT
It's bad when you think BMW has known about the E85 steering issues and allows the same thing to happen on the E89. I wonder if we will be hearing about the problem on the new Z4 in a few yearsenzed4 wrote: ↑Tue Jan 01, 2019 3:08 amI removed the steering cowl and had a look around. Looks like there's no equivalent adjustment ring for the E89 (at least as far as I can tell).enzed4 wrote: ↑Sun Dec 30, 2018 3:25 am Anyone know if this fix might be applicable to E89's? The symptoms are very similar to what I'm experiencing (go back to the original description of 'knocking' rather than light or heavy steering/stickiness). I've changed the 17" RFT's to 18" non-RFT, had wheel alignment done, and had garage check all the bushes etc (twice now). All that seems left is suspension (Bilsteins) or possibly the fix in this thread.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- MACK
This does definitely sound like there is "play" in something (something is worn excessively) rather than the sticky or light steering E85/6 folks experience. Honestly I think you'll achieve nothing under the cowling. IIRC the motor/control unit on E89's is in the same place its in on later EPS equipped BMW's, mounted on the actual rack itself in the engine bay.enzed4 wrote: ↑Sun Dec 30, 2018 3:25 am Anyone know if this fix might be applicable to E89's? The symptoms are very similar to what I'm experiencing (go back to the original description of 'knocking' rather than light or heavy steering/stickiness). I've changed the 17" RFT's to 18" non-RFT, had wheel alignment done, and had garage check all the bushes etc (twice now). All that seems left is suspension (Bilsteins) or possibly the fix in this thread.
I'd be looking again under the bonnet/engine bay area rather than in the car. Get them to check the rack itself with both the car running and switched off. Also id check the rack to column joint etc. A knocking shocker is a possibility but I wouldn't have expected the vibration on cornering if it was that. Check the front top mounts etc. In fact I guess check everything again maybe at a different garage. This sounds like a classic case of the hard part in fixing something on a car is knowing what it is in the first place. Good luck with it!
Silver 05 3.0i SE
White E89 20i M Sport
Glad you got it sorted, yes it makes such a difference to the steering.
Well done for offering help to others
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Thanks. The steering now feels much better. It's never going to be super smooth, but that goes with the territory.
Not a problem. It's not very often that I'm useful to anyone, so I do what I can...
- ULTRAVOX
So glad I joined this forum!!..I also have the "twitchiness" on the steering. I thought initially it was wheel alignment.So took it to BMW for it to be checked but wasn't out by much.
I would really appreciate some help with this PeteWard. If the offer is still open?
Black Z4 3.0Si Coupé E86 Auto with 19" 3SDM 0.01 silver polished wheels.
https://flic.kr/p/RPTxT1
2019-01-02_11-06-33 by Andrew Chandler, on Flickr
- enzed4
Thanks for the tips. It does look like it's been traced to the front shocks (the shafts and seals are worn/damaged) but I won't know 100% until they're rebuilt and back on the car.MACK wrote: ↑Tue Jan 01, 2019 12:03 pmThis does definitely sound like there is "play" in something (something is worn excessively) rather than the sticky or light steering E85/6 folks experience. Honestly I think you'll achieve nothing under the cowling. IIRC the motor/control unit on E89's is in the same place its in on later EPS equipped BMW's, mounted on the actual rack itself in the engine bay.enzed4 wrote: ↑Sun Dec 30, 2018 3:25 am Anyone know if this fix might be applicable to E89's? The symptoms are very similar to what I'm experiencing (go back to the original description of 'knocking' rather than light or heavy steering/stickiness). I've changed the 17" RFT's to 18" non-RFT, had wheel alignment done, and had garage check all the bushes etc (twice now). All that seems left is suspension (Bilsteins) or possibly the fix in this thread.
Gone: 2010 35i DCT
Absolutely fantastic post that's undoubtedly saved £££.
Recommend a good quality e11spanner. And be prepared to be upside down with your head in the footwell
Good luck
Good luck
ULTRAVOX wrote: ↑Sun Jan 20, 2019 11:25 pm So glad I joined this forum!!..I also have the "twitchiness" on the steering. I thought initially it was wheel alignment.So took it to BMW for it to be checked but wasn't out by much.
Where are you based? Anyone near Sheffield who would like this doing I’m happy to.
- ULTRAVOX
I'm in Evesham (or Cov) most of the time but don't mind the drive. This issue is starting to really annoy me. (Along with all the idiots that keep ringing about the sale of my 3 series!).
Has anyone got a price on how much bmw charge for this?
Surely this should have been a "recall" job?
Shame you're not closer! yours about 3 hours from me.ULTRAVOX wrote: ↑Fri Jan 25, 2019 9:18 am I'm in Evesham (or Cov) most of the time but don't mind the drive. This issue is starting to really annoy me. (Along with all the idiots that keep ringing about the sale of my 3 series!).
This is pretty straight forward fix. Trust me, if I managed it anyone can.
