Engine misfire carly code P0302
Online
sharpyboy
Post by sharpyboy » Mon Mar 23, 2020 1:43 pm
Hi Guys
As the title suggests i took my zed out to have a new tyre fitted and on the way back i noticed it running rough and a yellow engine warning light came on. I stopped and restarted the car and the engine warning light stayed off but the rough running continued so when i got home and plugged Carly in and it came up with a PO302 code which i think is misfire in cylinder 2. This could be spark plug/loose connection orignition coil so i wondered if there was any way to determine the exact item that needs looking at/replacing. Anybody else had this? is it common with zeds or BMW's? Any special tools needed to remove coil packs or spark plugs?
Any advice welcome, something to do while i'm social isolating :roll:
2006 Z4 2.5i gap-tech rch+ roof mod + zhp + roof motor now in boot + DLV Exhaust mod
Chris_D
Post by Chris_D » Mon Mar 23, 2020 2:16 pm
Swap a coilpack around and see if it makes any difference. If not, swap 2 plugs around. Process of elimination.
If that doesn't change the issue start checking condition of leads and other potential sources.
I'm banking on your plug being fouled. Check for sooty carbon deposit on head or oil on threads and head.
No special tools needed as the coils just pull out after flipping the tab up.
But make sure you use a plug tool with a fixed head, not just a ratchet and extension and head as the head will just pull off and get trapped in the plug tube when you try to pull out the plug. Don't ask me how I know this. :lol:
:thumbsup:
Online
sharpyboy
Post by sharpyboy » Mon Mar 23, 2020 6:25 pm
:thumbsup:
Thanks, I have just started the car up and it appears to be running OK, will do a test drive tomorrow and then check under the bonnet/hood for loose connections and do coil swap/ ug swap if needed, thanks Chris_D :thumbsup:
Online
sharpyboy
Post by sharpyboy » Tue Mar 24, 2020 5:34 pm
Well checked the car this afternoon and the misfire is back so cleared the codes in Carly and swapped the coil pack from 1 to 2, sprayed wd40 in the coil pack sockets and started the car to see if the fault moved with the coil position and all was clear, no fault again. So I will leave till tomorrow and see if the misfire is still fixed and take it for a run to check if the fault is back I'll check which cylinder it's on. :headbang:
Online
-Tom-
Post by -Tom- » Tue Mar 24, 2020 7:20 pm
Checked the plugs yet? I just lost my words when I pulled this out of my Mini Cooper S today (20k miles of use ) :rofl: :rofl: :rofl:
Believe it or not, that was for a misfire only under load with a temporary EML when it did so. P0302 code also up, although this was cylinder 1 and 2 was fine :driving:
-Z4 M Coupe, Silver Grey, Imola Red Nappa, carbon leather, CSLs, SuperSprint Race, Track Mode Enabled
-Mini Cooper S Clubman
Previous - 3.0 si sport roadster, Silver Grey with Oregon Pearl Grey leather, Piano black, EIbach Pro, Stubby
Online
sharpyboy
Post by sharpyboy » Wed Mar 25, 2020 12:51 am
Wow that's a large plug gap 😄 I haven't checked my plugs yet as I need one of those thin plug tools as the one I have from previous cars will not fit.
:thumbsup:
baconJazz
Post by baconJazz » Wed Mar 25, 2020 1:20 am
Exactly the same thing happened to me last week. Took it to BMW and a misfire was flagged up in cylinder 5. They did the coil swap for a migration test ,but still an issue with cylinder 5 . Changed all plugs at a cost of £187 and the car now drives better than it ever has in the 6 months I've owned it.. Job done. :driving:
2007 3.0si sport e86 coupe Black Sapphire 93k and rising at approx 2k a year.
Mazda mx5 mk3
Fiesta ST
Subaru WRX Blob eye
Mini Cooper S JCW
Mx5 mk1
Ford Puma.
Opel Manta GTE (1984)
Mk 1 Ford Capri 1.6 GT (1973)
Austin Maxi 1750 HL (269 BC)
noiseboy72
Post by noiseboy72 » Wed Mar 25, 2020 10:06 pm
I had this the other day - It went down to 5 cylinders and ran as rough as a fat lass from Ormskirk.
I put the scanner on it and it came up with Misfire Cylinder 5. Plugs are only 10 months old and it's only done 12K on them, so I'm fairly certain they are fine.
Reset and erased the fault and it's been fine since, but I will be keeping an eye.
E85 2.5si Sport in dark blue. Calibre CC S wheels
What could possibly go wrong!
Ewazix
Post by Ewazix » Thu Mar 26, 2020 5:57 pm
Hi Tom, you need to watch that on the Cooper S, drastic plug burning is a common problem and can indicate some serious engine damage is in progress. Best case is the plug being the wrong grade, otherwise it's a lean burn /pre-ignition problem caused by a faulty injector or possibly the common coking problem (hot coke deposits in the burn chamber pre-ignite the charge) either can overheat the cylinder, piston crown and valve seats causing potentially expensive damage. You may be hearing 'pinking' under load? My old S had the issue and was repaired under warranty catching it in time before a big re-build was required.
2018 Cooper S Countryman
Fiesta Ecoboost
Online
-Tom-
Post by -Tom- » Thu Mar 26, 2020 6:04 pm
Thank you! I’m really unsure what to do with it, my man maths means the car has to run the rest of the year with no major bills; otherwise I should have leased something :roll:
They’re great little cars, but chasing Problems on them really is an expensive minefield isn’t it.
I’m going to give it a full service and replace the extremely leaky rocker cover gasket. Then maybe a de-coke in order. :dizzy:
Sorry for the off topic OP. Any joy yet ?
