Water Problems!
- chrisgreen
Water Problems!
Hi All,
Found alot of water under the carpet behind the drivers seat - it's dry on top but the underneath acts like a sponge and it's soaking.
I've replaced the new door membrane and sealed properly using butyl tape (and also tested and it's fine). I've also pulled out the drivers seat out and the trim which holds the carpet in place and it's definitely not coming in through the door as the carpet around the door entry is bone dry.
Any ideas? I've done a quick search and someone mentioned the roof drains? Is this a possible cause?
the passenger side where the motor is located is fine and water runs clean through - the drivers side seems to run through(ish) but not as fast as the passenger side?
Is there anything else it could be? i cleaned out the drains once a few months ago using a metal skewer but seems like i might need something a bit longer!
'04 E85 Z4 3.0 silver/black - daily driver - Sold
'02 E46 M3 PY/Kiwi
'05 E46 330d Touring - Silver Grey/Black
'02 E46 M3 PY/Kiwi
Water Problems!
I’d clean out the drain holes again dude
Now: Z4MC Titan Silver
Gone: E86 3.0Si Sport Titan Silver - M exhaust + bumper - Battery Relocated - Aero Front
E86 3.0Si Sport Silver Grey - Carbon Diffuser - Aero Kit - B/Box Mod - Storm MW V2
E85 2.5 Si Sport Titan Silver
Water Problems!
I heard that underneath the windscreen scuttle you can get a build up of leaves etc which will in due course block the water outlets and then it can overflow into the car. Turns out its not that easy a job due to the plastic clips etc on the scuttle cover. Had some build up in mine but not enough to cause any issues. Now awaiting some plastic clips to put it all back.
- Markos_Z4
Water Problems!
you have a soundgenerator ? check the rubber from the soundgenerator under the hood i had same problem. . . . the front window drain is above the pipe that go inside your car, , , the water leaks behind the rubber underneath your carpet
M-Front & M-Rear Bumper / Aero Skirts / 9J + 10.0J 20 inch Barracuda Voltec T6 gloss black inox Lip / Custom Quad Exhaust / Gloss Black Painted Roof / Gloss Black Painted front Lip / M-Sport Suspension / M-interior
Follow me on Instagram https://www.instagram.com/markos_z4/
- Markos_Z4
Water Problems!
if you got water on top of your carpet you have to fix your door foam seal inside the door
https://www.newtis.info/tisv2/a/en/e86- ... ng/G7GqpGZ
got alle water leaks you can have with a z4 coupe all fixed right now
- Chris_D
Water Problems!
Pretty certain you need to clear out driver side roof drain.
Had exactly the same issue. Cleared the drain from top and bottom using a flexible drain wire and carpets have been bone dry ever since.
- chrisgreen
Water Problems!
Hi all- thread revival!
Still got water coming behind the drivers seat - its definitely not the door membrane as ive replaced and checked for leaks several times. Ive also cleared the rear drain holes and all running clear. Any ideas?! It looks as though its underneath the carpet as the top is never wet but underneath is soaking! Its only right at the very back of the cabin - underneath the seat is bone dry!
Help!
Help!
'02 E46 M3 PY/Kiwi
'02 E46 M3 PY/Kiwi
- Chris_D
Water Problems!
have you verified rear/roof drain holes are clear by pouring water through?chrisgreen wrote: ↑Sat Nov 24, 2018 6:57 pm Hi all- thread revival!
Help!
- Grumpyowl
Water Problems!
Is the boot area dry ? Do a search re boot air vents .
- chrisgreen
Water Problems!
Yes entire boot is dry and rear drains are flowing through perfectly!
'02 E46 M3 PY/Kiwi
'02 E46 M3 PY/Kiwi
Water Problems!
Did you ever solve this? I am having the same problem.chrisgreen wrote: ↑Sat Nov 24, 2018 6:57 pm Hi all- thread revival!
Help!
Harry
1970 VW Sunroof Bus - "The Magic Bus"
1973.5 911T Targa - "Smokey"
2003 BMW Z4
2009 MB C300
2003 BMW Z4
2009 MB C300
Water Problems!
My problem persists. With my car parked uphill (Nose up) the section next to the parcel tray on the right hand side fills with water and eventually drains into the trunk. I live in a hilly area so parking in a flat area is not an option. Attached is a picture of where the water seems to be entering the car. Where do I look to find the entry point?
- 2020-04-18 Top Water Leak 2.JPG (167.74 KiB) Viewed 1076 times
Harry
2003 BMW Z4
2009 MB C300
2003 BMW Z4
2009 MB C300
Water Problems!
These seem to do this, I park my car on the level or nose down hill and the boot stays dry
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
