So I have a high mileage (135k) 3.0 that idles smoothly and up to 4k rpm is very smooth, but at the 4k point it hesitates and surges.
I thought I had fixed it when I changed the DISA but it seems not. So for the car has had:
Vanos rebuilt
New DISA
New spark plugs
It always runs on premium unleaded if that makes any difference.
Any ideas what it could be as I'm stuck!
Edit: As an update, I just checked the MAF and the plastic grille thing in front of it was completely detached....is it required, I presume so hence it being there? Could this cause the issue?
Hesitation after 4k rpm
- thecremeegg
Z4M - Interlagos Blue with Black Leather
Z4 3.0i - Sapphire Black with Red Leather - FOR SALE!
It could cause an issue as it smooths the airflow to the MAF so that it gets a consistent reading.
Other issues could be as simple as leak in the intake boot.
- thecremeegg
The intake boot is an interesting one as it does look a bit old - no obvious leaks though but worth a shot as they're only cheap
- Fox889
Leaking intake boot should [?] ping up an EML light [as mine did].
Common fault on these girls, changed mine in a few minutes, bought the elbow from a main dealer & wasn't silly expensive.
Coil pack could be the next port of call?
Coil pack
2004 3.0 Z4 in Sterling grey metallic
Might be worth checking the battery, changed mine a few months back and it was quite surprising how much it improved the cars responsiveness
Midnight blue, 3.0si sport coupe, champagne nappa leather, piano black trim, stubby, DLV exhaust and a bunch of other stuff
Sounds like a coil pack? I had exactly the same symptoms. New coil packs/plugs, all now good.
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:Brand new Pierburg water pump fitted at 101k after failure (should have done it at 100k)
- thecremeegg
Update time: The intake boot was the cause. I put duct tape round the top where it looked suspect and the problem has vanished, no longer feel any hesitation at 4k rpm. Thanks mmm-five!
