Engine Warning Light 2005 E85 2.2
Boris
Post by Boris » Tue May 29, 2018 6:14 pm
Evening guys, my wife has just got home to tell me the Z has an engine warning light on. :thumbsdown:
Is there anyone in the Durham area with a code reader could help me please.
Many thanks in advance
Nev
Scooba_Steve
Engine Warning Light 2005 E85 202
Post by Scooba_Steve » Tue May 29, 2018 7:30 pm
If you have recovery they may come out to read for free.
Boris
Post by Boris » Tue May 29, 2018 7:34 pm
I have recovery, but the car is now at home and the recovery doesn't cover home visits unfortunately :-(
paddy wright
Post by paddy wright » Wed May 30, 2018 9:04 am
Push it onto the road :poke: Seriously though if it’s running ok then the chances are it’s an air leak. Check the intake boot that comes off the back of the air box- I suspect the smaller hose that braches off that will be split.
Boris
Post by Boris » Wed May 30, 2018 12:11 pm
Doh! I know it is but didn't think that would cause it!
Anyway I've arranged for a local guy to call out today to take a look with the diagnostic thingy, at least I know what to look for.
Cheers
Nev
Boris
Post by Boris » Wed May 30, 2018 1:26 pm
Sorted, the engine management light stayed on once I had fixed the leaking bung but once the guy read the fault which said lean on bank one which sounds right and cleared it the fault hasn't returned.
Job done cheers
Nev
Boris
Post by Boris » Tue Jul 17, 2018 4:22 pm
Well I thought it was sorted, Its happened a couple of times since the original and been re set both times only to re appear.
Sometimes when it is started there is a bellow of smoke out of the exhaust; I wonder if this could be a symptom of sticky piston rings with it standing around and not being used much, therefore showing a weak mixture on bank one on the readings when its checked.
Any suggestions?
ph001
Post by ph001 » Tue Jul 17, 2018 4:28 pm
Crankcase ventilation? Could explain the smoke out the back. There is a CCV valve that often gets stuffed up with gunk, as does the return pipe to the sump.
Boris
Post by Boris » Tue Jul 17, 2018 5:37 pm
But if this is gunged up wouldn't it blow the smoke out all the time??? not just on occasions on start up??
ph001
Post by ph001 » Tue Jul 17, 2018 6:58 pm
It causes oil to settle in the inlet manifold which could weep into the cylinders overnight.
Boris
Post by Boris » Tue Jul 17, 2018 7:05 pm
I noticed it did it within around 2 hours of my wife getting in from Work when I re started it.
Would this be enough time for that to happen do you think?
ph001
Post by ph001 » Wed Jul 18, 2018 9:40 am
It certainly leads to excess oil consumption but not usually a lean code - that's typically due to a split in the intake elbow small pipe...
split elbow.jpg (103.57 KiB) Viewed 974 times
Boris
Post by Boris » Wed Jul 18, 2018 12:24 pm
will take a look at that cheers
Boris
Post by Boris » Wed Jul 18, 2018 6:55 pm
Taken a look tonight and mine looks like new compared to the one you have in the image deffo no splits that's clearly not the problem .. back to square one. :cry:
ph001
Post by ph001 » Thu Jul 19, 2018 10:50 am
Airflow meter / lambda sensors next then I guess - lean codes could be a few things, can you post the exact codes? . You could do with looking at live values with INPA tbh.
