Sat Nav Retrofit Fitting Details
does anyone have pdf or diagram for how can i cut dash?
any measurement?
or any pdf for template?
any measurement?
- markplant
You might be better trying a breakers for a dash top from a nav car
- markplant
On eBay i think it's classiccarspares2016
Nothing like that...
- srhutch
- Moderator
Just do as I did and make your own. Just remember you can make the hole bigger, but not smaller.
- markplant
eBay number 263152522471
I just need template with paper to cut , not compleatly dash bro
- pvr
I have fitted two of these, if you take a thin piece of cardboard it is easy to make the cutout and you can test it using the screen. Point to remember is that there is a small edge at the front that you don't remove and the legs of the screen have holes that need to lign up with the screws under the dash surface.
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Jeep
Abarth 595 Comp.
Jeep
- srhutch
- Moderator
That's not a bad price. THey were £200 when I did mine and was looking for a just in case solution
- pvr
ah yes, your rush job
I took 3 evenings if I remember well, to avoid the just in case ... measure, re-measure, cut, cut a bit more etc
You did take 3 years to finish it off though
Never again though.
Never again though.
Abarth 595 Comp.
Jeep
Abarth 595 Comp.
Jeep
- srhutch
- Moderator
I did the measure twice cut once stuff, but the concern was the dremel slipping, although I did protect the dash the best I could.
3 years, you checky fecker
Where you been hiding anyway, not that we've missed you
hello
I want to upgrade navi system to my bmw z4 2006 , i buy radio professional and monitor, what else do I need to do?
What is the catalog number of the cables?
Best regards
Best regards
i need wiring loom serial number 61120301701
- Alemito
Where can i find a cutting template?
