03~05 FULL circle Brake light BRIEF
ATPDK
Re: 03~05 FULL circle Brake light BRIEF
Post by ATPDK » Fri Mar 29, 2013 5:09 pm
iPhone Tapatalk
xalli
Post by xalli » Sat Apr 27, 2013 11:01 am
nahodo wrote:No need of wiring, it's possible to program it with NCSExpert! Clean solution!
Please tell me, how to do it using NCS expert.
I'm afraid of wiring, but coding solution is ok for me.
Please tell me the function strings in NCS Expert to activate or deactivate.
Thank you! :P
BMW Z4R'03 merlot red, many bugfixes done...
AUX-In FL OEM,Full facelift,iPod OEM,M-steering wheel,Electric leather seats,RLS retrofit,Electric mirrors,ParrotBluetooth,M-hood,M-front, autodim mirror.
LukeMace
Post by LukeMace » Sat Apr 27, 2013 12:11 pm
It honestly takes 2 mins, if that to wire it! All you do is put in a bridge and its done! :thumbsup:
3.0, Quad Conversion, 19" CSLs, Bucket Seats, Big Brake Conversion, Lowered 40mm, AE and Clear Hockeys etc...
CLICK HERE FOR THE BUILD THREAD
markeg
Post by markeg » Sat Apr 27, 2013 6:58 pm
Done the wire bridge, very quick and easy, like this mod (and takes 2 mins to remove as well:) ) :thumbsup:
Tapatalking...
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
xalli
Post by xalli » Sat Apr 27, 2013 11:10 pm
ok, but I'm not sure about my wiring skills.
Somebody tell me how to do it in NcS expert!! :?
LukeMace
Post by LukeMace » Sun Apr 28, 2013 1:18 am
That's the good thing though mate, you need no wiring skills! Simply get some wire, strip the ends and insert each end into the correct terminal block... Done! If your anywhere near northampton, pop by and I'll be happy to do it for you whilst you have a cuppa!
I don't know how to code it, just wire bridge it :thumbsup:
markeg
Post by markeg » Sun Apr 28, 2013 1:22 pm
LukeMace wrote:That's the good thing though mate, you need no wiring skills! Simply get some wire, strip the ends and insert each end into the correct terminal block... Done! If your anywhere near northampton, pop by and I'll be happy to do it for you whilst you have a cuppa!
only additional thing I did was to solder the wires and flatten them to make a small spade-like connection
current: MB C-class
LukeMace
Post by LukeMace » Sun Apr 28, 2013 1:42 pm
markeg wrote:only additional thing I did was to solder the wires and flatten them to make a small spade-like connection
Probably better to do it the way! :thumbsup:
xalli
Post by xalli » Mon Apr 29, 2013 9:55 am
Guys, thanks for responce. I found NCS solution. 2 min and no wiring and my z whith full circle brakes=)
In light module:
STANDLICHT_ALS_BREMSLICHT
aktiv
BREMSLICHT_ALS_STANDLICHT
aktiv
All ok, no bugs detected :lol:
itguy
Post by itguy » Sat May 18, 2013 8:08 am
Just done this mod using the soldered link method.
I had a good look one side done vs the other 'standard' for the difference between between the sidelight brightness.
Yes it's a little brighter but really not that noticeable. The fact that when the brake is pressed the whole circle now lights up makes it very noticeable that you are braking and no one will miss the difference between side light and brake light.
V happy.
2003 Z4 3.0 SE Roadster. Manual, silver with New England red extended leather. Pro nav, xenons, carver hifi, elec fold mirrors, 6CD, dension gateway 100 iPod adaptor, tv, 108s, wind deflector. Fitted: Stubby, cruise control, ZHP, cup holders.
k.leeming
Post by k.leeming » Thu Jun 13, 2013 1:03 pm
BlackSapphireZ wrote:don't ever work on your car if you can't do this lol
it's 1st and 4th wire wired up together
RIGHT
LEFT
FULL CIRCLE BRAKE LIGHT
+1
Just done using this method although i spotted a glitch in what you wrote. I matched up all the coloured wires and yes they did sit in slots 1 and 4, on the RIGHT ONLY.
I had to reverse this method on the oppisite side, left, for this to work.
So on the left i had wires in slots 6 and 3.
If you are going to do this method roll down the black goo-ey tape and clip slots 3 and 6 together on the left and slots 1 and 4 together on the right.
Kane
Heated red Electric M-Sport seats, M-Sport Steering Wheel, 18" M-Sport Alloys, 2.0l Black Sapphire, Full Brake-light Mod.
No stubby, no style!
igeak691
Post by igeak691 » Mon Apr 14, 2014 3:45 am
xalli wrote:Guys, thanks for responce. I found NCS solution. 2 min and no wiring and my z whith full circle brakes=)
In light module:
aktiv
aktiv
Which one is the light module? ALSZ?
YouTube channel with car vlogs in my zed!
Please subscribe and share my videos with fellow enthusiasts!
nick&sandra
Post by nick&sandra » Sun Jun 01, 2014 5:12 pm
nick&sandra
Post by nick&sandra » Sun Jun 01, 2014 5:43 pm
markeg
Post by markeg » Sun Jun 01, 2014 10:59 pm
I did the mod through using a wire to bridge the connection. No complaints, sailed through MOT and much prefer the full circle look. IMHO the half circle looked like a bulb had blown :). So simple a mod there seemed no need for a coding alternative (never heard if there is one available)
current: MB C-class
