How to modify your CDV (Clutch Delay Valve)
maxman
Post by maxman » Wed Jun 29, 2016 7:03 pm
brainstorm wrote:Im maby planing to remove mine CDV but im a bit questioning...
BMW have put it there for a reason, what reason is that?
Dont think they put it there to make the drive experiance worse!
Will removing the CDV have Any negative effekt to the Clutch or the gearbox in the long run?
If you find you can set off in 1st gear without kangerooing,I would not bother doing it.
It depends on your driving technique wether you see a big improvement .
E89 2.3 Sdrive Sapphire Black.
srhutch
Moderator
Moderator
Post by srhutch » Wed Jun 29, 2016 8:49 pm
It's also the change into 2nd that improves. If it's a non ///M I would be surprised if you didn't notice a real improvement with it removed.
The CDV prevents shock to the drivetrain if you dump the clutch. If you drive the car with respect and treat as you should you don't have shy issues, and have never heard of anybody having issues after removing.
Ferglar
Post by Ferglar » Wed Oct 18, 2017 10:24 am
Good morning folks!
I appreciate I'm a bit late to the party!
But this is something I need to do! Does anyone have anyone they can recommend local to Bedford? Or a member who could do it for beer tokens!
Thanks in advance!
