Dear zedebee,
Thank you for the reply and the welkom.
unfortunately BMW stopped doing that in 2004
Retrofit Cruise Control
I did this last week and it was so easy. Thankfully I have an '03 and so was wired for it from factory. I find the stalk not very intuitive though compared to our Skodas.
Hi everyone! New to the forum, but already found it helpful! I have installed the stalk in my 2003 2.5i Z4 and it works! It came 146€ from Germany (I'm italian) and I just need to trim the plastic bit out.
Bye for now and thanks for the tutorial!
2003 2.5i Sterling Grau
I’m interested in fitting cruise control to my 2006 ‘facelift’ Z4 2.5. Most of the links I’ve clicked on don’t work any more, could anyone help me out with a link or an idiots guide?
Wayne
Wayne
Hi, I did it some months ago, do you need info for assembly or buying the part?
Hi
A bit of both really? I’ve read that on a ‘post 2004’ Z4 like mine that I also need to purchase a wiring loom? I’m looking for the part number for the stalk and the loom that I require? Also to find out if it’s basically still ‘plug and play’ on my model as well?
Yes you will need to get the wires. Or you can get the connections from a broken car. That is what i did. As for the links I can e- mail them to you. (I don't get how to upload pdf on this form)
You can plug it in. But you will need to program the computer to crusecontrol "yes".
Online
You need to buy a cruise control stalk and a loom. You can sometimes find a new stalk (try your dealer) for not much more than a second hand one which are typically £75-£100. You can get a loom from a breaker or get one from BMW. The go-to option was always to get a custom loom from srhutch, although I don’t know if he is still active on here. The srhutch looms are simpler to wire up, very reasonably priced and come with a full set of instruction. Fitting cruise control to my ‘57 plate coupe did not need any programming, it was plug and play.
2003 Maldives Blue 3.0i auto
If anyone is umming and ahhing about doing this; I recommend that you JFDI!
When I got my 2005 E85 I was hoping that it had all of the magic extras like CC and Heated Seats already wired but it appears the cutoff for pre wired cars is October 04 and my build date is March 05. So much to my disappointment all the upgrades are not plug and play so I have literally been sitting on this for 5 years because I was too scared.
Today I got the courage to install the kit and it took about 1 hour and was super easy barley an inconvenience.
Link to instructions http://www.bmwz3club.fr/site/faq/tempom ... fit_z4.pdf
Onto the Photos for anyone that has a 2005 Pre facelift M54 that needs Cruise Control
Cut the loom as per the instructions and splice in the two cables to the LCM connector Fish the cable across and into the engine bay. (Im using a spare bit of Cat5 as a draw wire to pull it through. ) Connect the Blue/Black cable into X60004 Fit the Stalk.
