How-to: Cheap brake upgrade
oalloyd1
Post by oalloyd1 » Fri Jun 02, 2017 1:42 pm
Yes indeed, its going to be doing some lapping going forward!
o :)
thanatu55
Post by thanatu55 » Sat Oct 07, 2017 3:44 pm
Has anybody performed the rear upgrade on a 2.0i E85? The fronts were no problem at all, but the rears are an issue.
I have sourced the calipers from a 325i and some 294mm drilled Brembo rear discs for a 325i to match the fronts, only to find the dish isn't deep enough to reach the 2.0i handbrake. In fact I haven't been able to find any 294mm drilled discs that would suit, it seems once you get to 294 they are all shallow dish.
Am I missing something here? It's frustrating to have gone through the whole caliper restoration procedure and sourcing everything I believe this guide points to, only to find they won't fit in the midst of the upgrade process.
Any advice would be greatly appreciated, thanks.
EDIT: READING THROUGH THE REST OF THIS THREAD IT SEEMS THIS ISSUE HAS CROPPED UP BEFORE, SO I WONDER IF THERE ARE ANY SOLUTIONS OR SHOULD I JUST FORGET THE REAR'S AND TRY AND GET SOME MONEY BACK?
Ducklakeview
Post by Ducklakeview » Sat Oct 07, 2017 4:07 pm
Z3 rears apparently fit, as well those from a 3.0se/si zed.
Mike
thanatu55
Post by thanatu55 » Sat Oct 07, 2017 5:43 pm
Thanks Mike I'll have a look at them.
Limonge
Post by Limonge » Thu May 10, 2018 11:59 pm
Hello,
Could you finally install the 320mm rear disc? Do they fit? I know there are issues with the parking brake, but I was wondering if it bolts up (leaving the parking brake useless)
LittleZ4
Post by LittleZ4 » Thu Aug 23, 2018 6:04 pm
I assume no one has got the 320mm to fit the rear with a working handbrake?? I'm about to order the discs and pads ready to do the upgrade. Not long refurbished a full set of front and rear calipers off a 330i.
Would love to have front and rears fitted.
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes.
