How-to: Cheap brake upgrade
Toe-side
Post by Toe-side » Sun Nov 06, 2016 8:14 pm
For me I identified the models that shared the correct calipers and carriers and searched 'Breaking' and 'dismantling' of those models on the interweb. Searched a lot under 'E46' rather than 330
The carriers do have markings on them but you would not be able to see what the markings were fitted on a scrap car.
I made the judgement that if I found a car being dismantled that had those parts fitted as standard then........... 'bingo' :wink:
Before: 2003 3.0 Roadster, Porsche Boxster 987S Now 981S
Success breeds complacency. Complacency breeds failure. Only the paranoid survive
Toe-side
Post by Toe-side » Sun Nov 06, 2016 8:16 pm
hopz121
Post by hopz121 » Sun Nov 06, 2016 10:05 pm
Mega cheap!
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
Toe-side
Post by Toe-side » Sun Nov 06, 2016 10:34 pm
Thats what I thought! Nothing to do with me......... just browsing and I found them :o
kis
Post by kis » Mon Nov 07, 2016 9:06 am
Thanks! I had a quick look, already sold!! :headbang:
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
kis
Post by kis » Mon Nov 07, 2016 9:12 am
Toe-side wrote:For me I identified the models that shared the correct calipers and carriers and searched 'Breaking' and 'dismantling' of those models on the interweb. Searched a lot under 'E46' rather than 330
Thanks for the replies mate. I've done the same, a lot of the cars that come up, once I call up requesting the part they've already sold. It's apparently a very popular mod with the old 3 Series too, the e36. The odd occasion they do have them they're asking in excess of £100. It's been mentioned a few times that they can be had for around £60. So looking at that sort of figure £60-80 ish.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
kis
Post by kis » Mon Nov 07, 2016 9:16 am
Found a reasonable one! Link here. I'm going to see if he'll let it go for a bit cheaper tho! :D
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
cj10jeeper
Post by cj10jeeper » Mon Nov 07, 2016 9:40 am
kis wrote:Found a reasonable one! Link here. I'm going to see if he'll let it go for a bit cheaper tho! :D
Why wouldn't you just buy them and before posting? If the calipers are trashed then you can use them as cores to trade in. If not then you have a bargain.
Someone is likely to see the post and just buy them
kis
Post by kis » Mon Nov 07, 2016 11:41 am
Just bagged a set for £70 from a breaker I contacted over the weekend so all good! :D
Also, I know some people are like that. However I'd like to think that since this is a forum, of fellow enthusiasts, I'm among friends.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
cj10jeeper
Post by cj10jeeper » Mon Nov 07, 2016 11:45 am
Brilliant that you have got a set :)
In terms of 'trust' I agree and in general you are right, however at any time there are up to 500 guests on the site. There are 200 now as I post this .., so it's a wide audience
kis
Post by kis » Mon Nov 07, 2016 11:51 am
cj10jeeper wrote:Brilliant that you have got a set :)
Yes, finally!
Noted about the second comment! I'll be more weary about things in future :?
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
MrPT
Post by MrPT » Thu May 04, 2017 10:59 pm
Someone at the Duxford meet (apologies - cannot remember your name Mr '58 plate Montego Blue owner from Bucks who's going to LM with Airtrack this year) was sporting E46 M3 front discs on his 3L coupe - identified with the help of some Rain Man action from Stu Boy.
I had a look at the specs...
So ok... stock pads won't sweep the whole disc, and fresh pads and discs will be a bit of a squeeze, but the hub fits and the diameter is perfect.
Doesn't this make new or part-worn E46 M3 discs a decent upgrade option for 3.0si owners? They are nice, 2-piece drilled rotors and supply should be plentiful (in fact, I think a stock surplus is how the aforementioned gentleman secured these discs at a bargain price).
2006 Z4 2.5si: gone
kis
Post by kis » Fri May 05, 2017 8:22 am
Interesting comment.
I think I did look into this but outlay seems to be quite a lot more than the 330, this is for parts whether new or second hand, and not sufficient gain. Also in terms of maintenance, just costs more because of the M name tag. Also I think the actual disc is the same (325mm) its just the thickness thats slightly more on the M. Obviously braking power of the M brakes themselves might be slightly more but not THAT much. Also some chatter on the 3 series forum about issues with the calipers being a direct fitment.
If it was a M3 CSL (which is 340mm or something) then this would probably be more "worth" it in terms of performance gains, provided everything fits. Wasn't too sure which is why I never pursed it myself. 330 is tried and tested...
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
cj10jeeper
Post by cj10jeeper » Fri May 05, 2017 8:54 am
The whole purpose of this thread is for a cheap, easy direct swap and bolt on conversion.
Once you start to mix and match, add pads that don't fit, ///M parts it'sa different topic altogether.
MrPT
Post by MrPT » Fri May 05, 2017 9:43 am
cj10jeeper wrote: Fri May 05, 2017 8:54 am The whole purpose of this thread is for a cheap, easy direct swap and bolt on conversion.
Fair point. I did think that "bolt on" 2 piece floating rotors and >5kg less unsprung mass for ~£200 was pretty good value, but yes - not cheap compared to the other options in this thread.
Point is probably moot now. Doing a little more digging, I think they were actually these OE option for the 3-series. And those definitely aren't cheap!
2006 Z4 2.5si: gone
