How-to: Cheap brake upgrade
Panta Rhei
Re: How-to: Cheap brake upgrade
Post by Panta Rhei » Tue Sep 15, 2015 2:06 pm
I have read about Porche 911 996 front Brembo calipers. If I am right - 330 mm. Maybe this is a chance.
Ducklakeview
Post by Ducklakeview » Wed May 25, 2016 9:58 am
Would the fronts from an E46 330CD be the same as the E46 330i, and therefore a straight swap to my 3.0i Z4?
Mike
Darkangelv2
Post by Darkangelv2 » Wed May 25, 2016 11:36 am
Ducklakeview wrote:Would the fronts from an E46 330CD be the same as the E46 330i, and therefore a straight swap to my 3.0i Z4?
Mike
Yes - :thumbsup:
BMW Z4 2006 2.5SI - BBS OEM 216 Wheels - Strut Brace
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper -
BC Racing BR Coilovers - Stainless Exhaust Bypass - AFE Stage 2
SonnyA85
Post by SonnyA85 » Sat Aug 06, 2016 12:17 pm
Mike
Can you get these new anywhere or is it too expensive and your better off just buying second hand and if they fail replace with second hand again.
cj10jeeper
Post by cj10jeeper » Sat Aug 06, 2016 1:37 pm
Mike
Of course you can buy new but would needs carriers too. Better buy second hand and clean them up or use those to trade in for refurb end units. New disks of course not old stuff.
SonnyA85
Post by SonnyA85 » Sat Aug 06, 2016 1:54 pm
cj10jeeper wrote:
Mike
what would you say is a good price then for front calipers, carriers and discs? They tend to be sold all together I find or you get 1 caliper and no carrier but asking stupid money in comparison to an all in one set.
cj10jeeper
Post by cj10jeeper » Sat Aug 06, 2016 4:40 pm
I just called breakers yards and they sold me calipers as singles. Threw in the carrier for free.
Can't recall prices, but supply and demand. When I did mine it was a new idea so cheap as chips.
Replacements since are around £50 exchange
Disks and pads depends on what you choose. I like EBS grooved and their pads.
kis
Post by kis » Fri Oct 14, 2016 12:55 pm
Just researching this for another to-do on my list. Is there any other calipers and carriers that would suit the Zed? I'm going to upgrade to the 325mm so at present I've got Z4 3.0si and E46 330's to choose from. Just wondering if there are any other sources out there that I could pursue?
Rare '15 Plate E85 Z4 3.0i SMG
1 Series - E87
3 Series - E46 320ci, E46 M3, E90 (x2)
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
X5 - E53, E70
X6 - E71
7 Series - E32
cj10jeeper
Post by cj10jeeper » Fri Oct 14, 2016 3:32 pm
kis wrote:Just researching this for another to-do on my list. Is there any other calipers and carriers that would suit the Zed? I'm going to upgrade to the 325mm so at present I've got Z4 3.0si and E46 330's to choose from. Just wondering if there are any other sources out there that I could pursue?
If you're talking about bolt on swops then the E46 330 is the route to go down. I'm not aware of any other caliper and carrier combo that is a direct swap
MACK
Post by MACK » Fri Oct 14, 2016 6:11 pm
if you look at real oem the 3,0Si calipers and carriers are the same on the 330d and the 325i as well as the 330i
Silver 05 3.0i SE
Major Mods- Zito935 F/L Xenons 4 Spot Clear Rear Lights M Sport Seats & SW ZHP Carbon Dash Eibach/B4 3.64 DIFF Cruise MM Tips
White E89 20i M Sport
Mods- Bilstein B12, CDV Delete, Manual Exhaust Flap
kis
Post by kis » Mon Oct 17, 2016 7:21 am
cj10jeeper wrote:If you're talking about bolt on swops then the E46 330 is the route to go down. I'm not aware of any other caliper and carrier combo that is a direct swap
MACK wrote:if you look at real oem the 3,0Si calipers and carriers are the same on the 330d and the 325i as well as the 330i
Thanks for your replies guys. Yes, just a standard bolt on set up. Don't want to be getting too technical or end up working myself into a messy situation.
I knew about the 3.0si (Z4) and the 330's (e46) but didn't know about the 325i? Is this a e46 as well? Or a newer 3 Series? I think you've got e90, e92, etc? This is a good shout and will hopefully mean I can grab something a bit easier and maybe cheaper as well.
Cheers, Kis.
1 Series - E87
X5 - E53, E70
X6 - E71
7 Series - E32
Ducklakeview
Post by Ducklakeview » Mon Oct 17, 2016 9:14 am
I used carriers and calipers from an E46 330d. They went straight on. Coupled with new slotted & dimpled discs and quality pads, they have made a massive improvement in braking. I paid £60 delivered for compete front hubs, but only used the carriers and calipers.
Mike
cj10jeeper
Post by cj10jeeper » Mon Oct 17, 2016 9:22 am
Cheers, Kis.
I have never heard of 325 calipers fitting, but if they carry the same size disk as 330's then they will fit. You can cross reference any part numbers on realoem.com
kis
Post by kis » Mon Oct 17, 2016 9:31 am
325 is only 300mm? So apparently not? Unless someone can direct me otherwise?
http://www.realoem.com/bmw/enUS/showpar ... Id=34_0758
1 Series - E87
X5 - E53, E70
X6 - E71
7 Series - E32
kis
Post by kis » Mon Oct 17, 2016 9:32 am
Ducklakeview wrote:I used carriers and calipers from an E46 330d. They went straight on. Coupled with new slotted & dimpled discs and quality pads, they have made a massive improvement in braking. I paid £60 delivered for compete front hubs, but only used the carriers and calipers.
Mike
Thats really good. I've been looking and most places quoting me around £150!! ...the search continues.
1 Series - E87
X5 - E53, E70
X6 - E71
7 Series - E32
