20ducks' Caliper Coating process
20ducks
Post by 20ducks » Sat May 23, 2009 5:58 pm
Here is my process for coating calipers. The color, of course, is your personal preference. I have used both foliatec and G2 coatings (very similar) both are excellent coatings - done right the coating will last a long time.
The "BMW" mylar overlays are available off eBay or PM me for a good source. They come 6 in a set so if you goof one up you have extra.
You can of course take the caliper off the rotor and hang from something. You do not want to pull on the brake line at any time. Brakes are your friend, don't mess with the lines, even SS brake lines. Some remove the caliper off the vehicle altogether and have the calipers powder coated. My method is to leave the caliper on the vehicle, prep and coat. For bandwidth sake I only took photos of the front calipers.
PUT YOUR VEHICLE ON JACK STANDS. THERE IS NO SUCH THING AS A SAFETY SHORTCUT. IF THE VEHICLE SLIPS AND YOU OR ANY PART OF YOU ARE UNDER YOU WILL BE SERIOUSLY HURT. MAKE IT SAFE OR BE STUPID.
Photo one is of the standard caliper that has had a light coat of black spray paint put on it. Doing this project takes a couple of days minimum so I had to pick a good time when you have enough time to complete the project. Cold damp weather doesn't help the curing process, so do this when it is at least 60F and a somewhat dust free environment.
TOOLS:
Part of this project was to work the face and part of the caliper to a smooth polished finish. Basically the caliper area that is in plain sight. I have a medium sized compressor that will run a die grinder. I used a course grit disc then medium grit disc to remove any paint rust and surface contaminants and remove all the castings lines, bumps and rough areas. These tools and products can be purchased from a shop that cater to body and collision shops. Don't know where one is, call a body shop and ask them were they buy their shop supplies and products. Pep Boys and Halfords etc., don't usually carry items like this. Brass brush is to help prep as is the grey scotchbrite pad. You'll want to wear a face mask because the dust from the caliper material is dirty and not good for your lungs. You already know what the various paint brushes are for.
I first worked the front of the calipers with the roughest disc first:
Although the photos don't show it very well, the surface is becoming much smoother:
Now you want to turn the steering wheel to allow as much frontal access to the caliper:
Clean the back area of the caliper with chemicals and a wire brush where possible to help coating adhesion:
I did not use the grinding discs back there. You just need to rough it up:
BEFORE coating only mix a small amount of paint (add the hardener) because this paint gets tacky very quickly.
Don't stop and start, use light coats I used 3 very light coats, allowing the coating to dry a few hours before adding the next.
Highly suggested: Use an adhesion promoter like this one before coating:
I used G2 for the calipers and duplicolor for the brake pad backing (this will peel away in a few months of regular driving so totally optional):
WERD: I prepped front & rear calipers before I painted. Trust me because if you mixed not enough paint it is easier to go back to the backside of the
rear caliper with the next mixed batch of paint. By the time the first coat is cured any paint (if you mixed too much) is hard as a rock and can't be
used anyway. Oh yeah, clean your brushes after use otherwise have several of the same size and type available for the next coat.
NB This is a tough, tedious, dirty, messy project. The success relies on your determination to be patient, follow instructions to the letter and perform the most outrageous preparation.
IMHO the results are worth it.
My caliper springs will be chromed soon.
Good luck...
Cheers,
Greg
2 Zero
Re: 20ducks' Caliper Coating process
Post by 2 Zero » Sun May 24, 2009 4:43 am
PhilDZ4 wrote:Work of art... :thumbsup:
Are you sleeping with him??
Out driving my car!!
See ya on the road!!
jhbuining
Post by jhbuining » Sun May 24, 2009 8:59 am
Why didn't you paint the ///M logo? Those rims are sooo shiny, you must be able to see it in the reflection :D
BMW Z4 3.0si Coupe RubyBlack & Honda CB1300AS
z4alfie
Post by z4alfie » Sat Feb 13, 2010 6:48 pm
I read this thread ages ago and wanted to paint my calipers bit couldnt find time to do them. Anyway, I recently replaced my MV2's with MV3's and this means you can see more of the disc and calipers. So today in the freezing cold, I jacked the car up using a jack from a 1995 Fiesta (It fits perfectly in the groove under the car and also stows in the compartment in the boot as if it was designed to go there.) took the wheels off, cleaned them and and used Autoglym alloy wheel sealant front and rears so they are all blingy now. Used STP brake component cleaner spray which just sprays on and evaporates, leaving the parts all degreased and ready to paint. Removed the pad retaining clips and painted them with black smoothrite, painted the calipers in silver ( I had the red but bottled it at the last minute) before putting them all back together.... repeat three more times and they look great. Ill post pics tomorrow because it was dark by the time i had finished. All ready for the North East Drive out on the 21st of March.
Titanium Silver roadster, Mods: MV3's Stubby, M Steering Wheel, Cruise Control, Chrome exhaust tips, carbon fibre grilles, remote hood, Loads of wax!Image
z4alfie
Post by z4alfie » Sun Feb 14, 2010 3:24 pm
Pics of my newly painted calipers. looking good. Image Image Image
VENDAR
Post by VENDAR » Wed Oct 24, 2012 12:13 pm
The photos can't be seen can you re-upload them please?
Dubdemand
Post by Dubdemand » Sun Aug 18, 2013 4:15 pm
Have the photos for the guide died or am I doing something wrong? Any chance this could be updated please?
Liam-O
Post by Liam-O » Sun Aug 18, 2013 4:42 pm
Dubdemand wrote:Have the photos for the guide died or am I doing something wrong? Any chance this could be updated please?
They're dead. Someone asked for them to be reuploaded 10 months ago and there not showing so I guess that's it
Liam - O
2005 Z4 2.2SE Grey
:rtfm: HOW TO: Fitting a Z4M Bumper
2dogs
Post by 2dogs » Sun Aug 18, 2013 4:55 pm
what colour would look right on a Interlagos blue ?
Blue Z4MC
Stuart Truman
Post by Stuart Truman » Sun Aug 18, 2013 5:27 pm
2dogs wrote:what colour would look right on a Interlagos blue ?
Yellow :thumbsup:
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
BeemerMad
Post by BeemerMad » Thu Mar 20, 2014 9:00 pm
Is there anywhere you can get phoenix yellow brake calliper paint?
Who is online
Users browsing this forum: No registered users and 1 guest
