35iS exhaust side
ColdKilla
35iS exhaust side
Post by ColdKilla » Thu Aug 17, 2017 3:46 pm
Hi everyone.
Excuse my ignorance but with the split exhaust on the 35i and 35iS do both tail pipes work all the time or does it switch from one to both when things are ramped up?
Just curious!
Maniac
35iS exhaust side
Post by Maniac » Thu Aug 17, 2017 6:59 pm
So it's a true dual exhaust, one per bank of 3 cyls.
One has a flap that opens and closes to reduce noise emissions largely at start up.
Smartbear
35iS exhaust side
Post by Smartbear » Thu Aug 17, 2017 7:01 pm
Maniac wrote: Thu Aug 17, 2017 6:59 pm So it's a true dual exhaust, one per bank of 3 cyls.
I thought the flap opened at start up to make it sound more growley :?
e85 3.0si sold
extrablatt
35iS exhaust side
Post by extrablatt » Thu Aug 17, 2017 7:40 pm
Cool, had no idea! Now I know :D
2013 E89 35iS Mineral White
19" 326M | heated seats & wheel | pro nav & hifi | stubby
Gone: 2010 E89 23i Space Grey
Zed Five
35iS exhaust side
Post by Zed Five » Thu Aug 17, 2017 9:33 pm
On start up, both will be ooen
on warming up, just the left side will be open.
Driving, it'll be adaptive.
Why is it that people who can't take advice always insist on giving it?
E89 35is | BMW S1000rr Motorsport Ed.
Diego_F
35iS exhaust side
Post by Diego_F » Tue May 15, 2018 12:30 pm
Zed Five wrote: Thu Aug 17, 2017 9:33 pm On start up, both will be ooen
I'm interested in that. How can I check if my rigth exhaust flap is working? I've never seen it closed and maybe the previous owner did something in that way to be always open.
2012 E89 sDrive35is Black Sapphire
ColdKilla
35iS exhaust side
Post by ColdKilla » Tue May 15, 2018 12:41 pm
just have a look underneath at the (drivers side exhaust in the UK) if the little hose is connected - once you get under it's quite obvious
Nick9one1
35iS exhaust side
Post by Nick9one1 » Tue May 15, 2018 2:39 pm
I thought the flap was closed on a cold start to reduce noise? My flap doesn't work and it sounds like it has a blowing exhaust for about 20-30 seconds until the idle comes down.
Another similar thread just started here - viewtopic.php?f=23&t=105901&p=1542990#p1542990
You should be able to move the arm with your finger - https://photos.app.goo.gl/ZE5YJAyFpj8p24jd2
Z4 35i Space Gray, Red Leather
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
Maniac
35iS exhaust side
Post by Maniac » Tue May 15, 2018 4:46 pm
They frequently fail, leaving a rattle or not working at all. I’m on my second and even that’s Jerry rigged with a spring to help it close. German rubbish.
Nick9one1
35iS exhaust side
Post by Nick9one1 » Tue May 15, 2018 4:51 pm
I've just found a much better solution to remove the 'rasping'/'hole in exhaust' sound at startup.
http://mhdtuning.com/
Very highly rated on other BMW forums, especially 3 series related. It's only for N54's/N55's though.
Now I'm running the golf tee mod and these options;
The cold start noise reduction works better than I expected. Very happy :)
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
Maniac
35iS exhaust side
Post by Maniac » Tue May 15, 2018 5:04 pm
Nick9one1 wrote: Tue May 15, 2018 4:51 pm I've just found a much better solution to remove the 'rasping'/'hole in exhaust' sound at startup.
That looks interesting. Can anyone point me to the two cables they state are required? (eBay?)
Diego_F
35iS exhaust side
Post by Diego_F » Tue May 15, 2018 5:20 pm
Nick9one1 wrote: Tue May 15, 2018 2:39 pm
I asked already in the other thread. Is that video opening the flap when pushing up the lever or closing it? Mine is open when engine is off or at idle.
Nick9one1
35iS exhaust side
Post by Nick9one1 » Tue May 15, 2018 7:23 pm
Yep I replied to your thread earlier.
The flap defaults to open when the engine is off. you push the arm to close it.
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
Nick9one1
35iS exhaust side
Post by Nick9one1 » Tue May 15, 2018 7:49 pm
Maniac wrote: Tue May 15, 2018 5:04 pm
This is the main cable you need. Some have a small switch on top, but you shouldn't need it for the Z4. It bridges pins 8 & 9, making it work with older BMW's.
https://www.ebay.co.uk/itm/For-BMW-INPA ... SwrIlaw9iZ
This is the second cable
https://www.ebay.co.uk/itm/Micro-USB-Ho ... xyeZNTVRfU
The app come in two parts. The flasher module (main app) is £89 which allows you to flash a stock map and fiddle with the options you can see in the screenshot.
Then there are additional Stage 1, 1+, 2, 2+ maps available at about £50.
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
Maniac
35iS exhaust side
Post by Maniac » Tue May 15, 2018 7:59 pm
Fab thanks.
Mainly want it for logging to get to the bottom of my engine injector issues. Then it’s playtime because frankly why not.
