No problem. have you tried ISTA or INPA? Probably better for logging/diagnostics.
They will work with the same cable https://www.ebay.co.uk/itm/For-BMW-INPA ... SwrIlaw9iZ
That cable seems cheap. Plus it states for cars up to 2008? There are others up to £40 or more, there’s conflicting thoughts online about the cheap cables bricking ECUs...Nick9one1 wrote: ↑Tue May 15, 2018 7:49 pmThis is the main cable you need. Some have a small switch on top, but you shouldn't need it for the Z4. It bridges pins 8 & 9, making it work with older BMW's.Maniac wrote: ↑Tue May 15, 2018 5:04 pmThat looks interesting. Can anyone point me to the two cables they state are required? (eBay?)Nick9one1 wrote: ↑Tue May 15, 2018 4:51 pm I've just found a much better solution to remove the 'rasping'/'hole in exhaust' sound at startup.
http://mhdtuning.com/
Very highly rated on other BMW forums, especially 3 series related. It's only for N54's/N55's though.
Now I'm running the golf tee mod and these options;
The cold start noise reduction works better than I expected. Very happy
This is the second cable
https://www.ebay.co.uk/itm/Micro-USB-Ho ... xyeZNTVRfU
The app come in two parts. The flasher module (main app) is £89 which allows you to flash a stock map and fiddle with the options you can see in the screenshot.
Then there are additional Stage 1, 1+, 2, 2+ maps available at about £50.
Any idea how this affects warranty?Nick9one1 wrote: ↑Tue May 15, 2018 7:49 pmThis is the main cable you need. Some have a small switch on top, but you shouldn't need it for the Z4. It bridges pins 8 & 9, making it work with older BMW's.Maniac wrote: ↑Tue May 15, 2018 5:04 pmThat looks interesting. Can anyone point me to the two cables they state are required? (eBay?)Nick9one1 wrote: ↑Tue May 15, 2018 4:51 pm I've just found a much better solution to remove the 'rasping'/'hole in exhaust' sound at startup.
+1 although mine is now the extended BMW warranty with AWP Assistance/Allianz.
It can do both.eff1guy wrote: ↑Thu May 17, 2018 11:36 am+1 although mine is now the extended BMW warranty with AWP Assistance/Allianz.
Had a look at the MHD site but confused as to whether it uses your own stock map to revert back too, or one of their own? The reason I ask is it lists the 35is but shows the stock map as 306hp when it's 340?
Would almost certainly void it if they found out. You could always restore the backup if you need to make a warranty claim though.
In my experience they're identical. I have a £50 cable and a £10 cable. Internals are the same.
Nick9one1 wrote: ↑Tue May 15, 2018 8:20 pmNo problem. have you tried ISTA or INPA? Probably better for logging/diagnostics.
Cables and INPA arrived. Will take a look tomorrow but want to be careful as INPA and inexperience seem to make for a bad combo.
