Situation:
Roof perfectly closed, not touched on this day, but one of the boot lid switches sent a wrong "open" status, the other switch sent a correct "locked" status. The internal led flashed in red, the windows could not be closed, the boot could not be opened.
ISTA+
There is a service function on the CTM module to lock and unlock the "softclose" mechanism. These actors (motors) on both sides of the trunk locking system turned to open or close. So far so good....
But - this doesn't open the trunk lid, only the softclose locking. That's a big difference!
There is a 3rd motor in the middle of the rear locking system, that has to pull the two wires to unlock the latches. That is the fuctionality, where you guys placed the unlocking hack behind the BMW emblem.
I was not able to execute the ABL (i.e. "Ablauf", like "process") function to drive this 3rd actor. Neither in the CTM module, nor in the JBE (junction box) module. This ABL fuction was greyed out due to the real failure situation. No way to get into the trunk in this faulty situation with ISTA+.
At least, I once again solved it with the pin12 method.
Does anybody of you guys know another option/function in ISTA to open the trunk lid?
In the next days I will try it once again on my own Z4, currently without any roof fault. Will come back soon...
Update
How it works internally:
viewtopic.php?p=1967743#p1967743
